07 Yukon - Aftermarket Replacement of OEM Backup Camera
Ledesordre
Thanks! Much appreciated
Okay sweet!
So on the factory camera harness plug that is not the furthest one to the rear but the one right before that (picture of it) I cut and spliced 3 of the wires and left one cut.
1 cut gray wire and left alone
2 Orange wire (factory 6v wire) wired this to the short red wire coming out of the new camera rca connector
3 white or pink w black stripe - factory ground, cut and splice to ground on camera ground wire
4 oem white wire cut and splice to new camera video wire
5 factory 12v in rear wiper motor, thick pink w white stripe, cut it and splice it back together but first one of the cut sides with the new camera power red wire
I know my pic is grainy but it’s pretty clear in real life
Ledesordre
Hope this helps. I haven’t made everything all tucked and neat yet. Still trying to figure out why my liftgate won’t close on its own before I bundle everything up nice and put the panel back on.
046D2A0B-2CE7-497A-90A4-8D5D19A9CFCE.jpeg C88F71BE-9248-4EA2-BE80-F5119874D5A6.jpeg 125AB05A-75E3-443D-A346-E73C4D77A640.jpeg 96F2C180-7803-4948-BE99-9DF9CDDB5EBE.jpeg 7BE32C1C-BE1D-44B4-B52B-5E5AD6FAADE4.jpeg
Ledesordre
I also spliced a female RCA connector in but you could just cut the RCA connector on the camera and go from there.
L
Larry07Yukon
Alright it worked! It's dark so I can't comment on the image quality during the day, but it is far superior at night
L
Larry07Yukon
I have to adjust the line markers, this unit supposedly has the ability to adjust width and length I believe
L
Larry07Yukon
Yeah
Looks great!
Thanks for all your help, this thread turned out great! I'm so glad I didn't have to spend $150 for a stock camera that isn't too good to begin with
Here's the camera I got, so far so good. The body is real nice, feels like a marble, definitely not plastic! It's a bit smaller than stock, I rigged up some small foam pads and caulk.
Ledesordre
Looks close to what I picked up, same look and price-about.
Really happy to have a backup cam now, mine had been broken since I got the truck
Xafnyx
I know this thread is super old and this is a long shot, but I have to replace my factory camera.... Again. And I'm tired of spending money on "oem replacements". I can't really tell from the photos above but you don't just cut the oem connector off and wire up the aftermarket camera?
Big Mama
Virginia
It’s been a while but I don’t recall cutting the wires. Either the pigtail came out when I pulled out the old camera or I got to it behind the inner lift gate panel.
HeavyHoe03
