07 Tahoe/Oil leak in the front
U
ukrkoz
Auburn WA
Not sure, what "this" is, but I do have fluid evacuator. I literally have two garages with tools. I already have radiator on order, sounds like will replace it in 2 weeks. For now, Bar's is in. Rad is leaking from about mid height left side. not even sure, how come I didn't see it before, pretty obvious. Oh, just saw the Amazon link. Exactly what I have. Had for 3 yrs by now. Yep, handy thing.
U
ukrkoz
Auburn WA
BTW, can't use that to evacuate coolant, as rad does not have cap. Evacuating from expansion canister will do little difference on fluid volume.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
You suck the fluid out from top to bottom as you dissemble overflow tanks/ heater and radiator hoses/etc.
U
ukrkoz
Auburn WA
OK, replaced radiator.
Wasn't hard at all.
Maybe an hour.
messy. Very messy.
U
ukrkoz
Auburn WA
It's really not that bad. I posted yesterday a basic write up here on how to. YT videos for some reason tell you to lift the vehicle up, disconnect harness braid from the crossmember, remove airbox, remove radiator plastic cover, remove front pass wheel and tirewell cover to get to the lower rad hose - all that is unnecessary. Very straightforward job and requires only 10mm, 15mm and extension for 10, to get to the lower ATF line bolt. Very simple.
X-ray Nerd
