05Single's virgin build thread. 03 tahoe
05Single
05Single
afraid of the dark
I like it. No chrome on roof racks looks good dave. Truck is looking good dood, wait.... is that sun? No snow? Wtf?
one day of sun, I’m not set in summer mode just yet
What paint did you use for the calipers? They're nice and shiney. I used high temp red and they're looking a little ragged.
VHT engine paint. More colors were available, the parts store only had red and black for calipers
for some reason it pops out more then the chrome, i like it great job 05Singal
I think so too, changes the whole look of the truck drastically
05Single
05Single
afraid of the dark
Forgot to mention the 26s don’t rub up front but they do in the back. so I had to bust out the Dremel and cut out the bulges for the shock mount and height sensor.
05Single
05Single
afraid of the dark
Did it rub on side to side weight transfer?
Yep, straight line and side to side. Then I cut them and it still rubbed but only on hard 90 degree turns. I thought for sure the front would rub , but nope it was the rear plastics, lol go figure.
BADRIDES
Did the 20's rub?
05Single
05Single
afraid of the dark
So I only know how to replace stuff that I’ve had to replace, if that makes sense lol. Steering isn’t one of them. I smacked a curb head on pretty hard few weeks ago. The alignment was slightly off but nothing seemed broken. After I put the 26” wheels I think they loosened up what might have been damaged and now when I hit bumps there’s a clanking. Not when I turn though. I feel like its the tie rod. But with it up in the air I can’t mimic the sound. I have a buddy who builds bag trucks that lay frame look at it this week. Fingers crossed it’s nothing too major.
BADRIDES
Upgrade those sway bar links while you are in there.
05Single
05Single
afraid of the dark
I know, those are next on the list. All the cool stuff is done. Now time to focus on mechanics and maintenance. But for the most part everything should be good-n-tight. This is the first mechanical issue I’ve had with it besides alternator. It had a full something like 200 point inspection when I bought it. I baby it so if it’s not broke I probably won’t upgrade anything. But we will see. First I need a job and money lol
Hope you get it sorted out, and nothing too serious.
05Single
05Single
afraid of the dark
So....um.... my weak ass didn’t tighten the calipers down tight enough and it came loose. That was the sound I was hearing :facepalm: . @ScottyBoy can let us know what could’ve happened if that caliper came off on the hwy:bawl:
So I tightened down the caliper (100 lbs) and the sound was gone. But my alignment was still off so I took it in to the shop just to find out it can not be aligned because it needs parts . So next posts and mods will be pretty boring
So I tightened down the caliper (100 lbs) and the sound was gone. But my alignment was still off so I took it in to the shop just to find out it can not be aligned because it needs parts . So next posts and mods will be pretty boringView attachment 223641
Pitman and idler arm is typical. Real lucky on the caliper!
HiHoeSilver
Away!
Chicago
Is the phone # not working, or your mechanic is #notworking? Lol
jk6062
