bill9000
- Joined
- Sep 24, 2018
- Posts
- 44
- Reaction score
- 14
Hi, trying to nurse this old 01 Yukon (5.3) I have through the winter... (has 142,000 miles) not going so well.
I had cleaned the throttle body, it was BADDDDD. Then it was randomly dipping idle at stops and sounding like a little miss. (I also put new plugs & wires)
So today, I went and replaced the Throttle Position sensor and the Idle Air Control valve. Both brand new in an attempt to fix the idle.
It was unsuccessful, there was no change, if anything it is worse, because now when you start it... it immediately idles all the way down and quits. the only way to keep it going is to hold the throttle up a little.
It runs fine, does NOT idle high like everyone talks about, it idles real low and tries to quit at red lights...
I tried the run for 3 mins at idle, like was suggested on YouTube, shut off for min, then repeat... that did not work.
Is there anything else I can do??? it's supposed to snow the next two weeks straight and I'm screwed if I can't fix this thing!
** there is NO code, no CEL, and nothing else wrong except for rough and low idle)
Thanks in advance for any help!
