01’ Camber caster
SmileB44Death
Seattle
Hello so my left lower control arm is missing a pin has this happened to someone? And how do I go about fixing this or where can I order the part?
A6261740-5C86-451F-A7FA-6EB55EE79CE2.jpeg 006D8E00-2D7F-4B67-8854-8BEA6DC81D8B.jpeg
Chubbs
SmileB44Death
SmileB44Death
Seattle
Thanks for the feedback. However, it’s more of this rod thing that’s missing (circled).
Here’s the rod intact on my right side lower control arm.776D02F5-D4B3-4A68-880A-06515DB9422C.jpeg
Here’s my left side where it’s missing the rod
04Huck
"I'd rather be lucky than good"
Buford, Ga
Yeah those little guide pins that both these guys listed are what you're missing. They're just pressed in, I've got 2 that are loose and trying to come out. It happens when someone tries to crank the cam/control past the point where it's stopped up against those pins. I bought some Belltech alignment cams for my truck when I dropped it and found out the hard way that the sweep is completely different and won't work with stock arms. I pulled one of my alignment cams straight out of its mount lol
04Huck
Buford, Ga
With a hammer/pry bar/flathead screwdriver/any combination of those
varminpoolteam
