New Safe coming 2003 to 2006 GM Fullsize
RGNEWELL
Supporting Vendor
I have wanted to build a safe for the 2003 to 2006 Suburban, Tahoe and Yukon for some time, also for the 2003 to 2006 FS Pickups. The problem was that the consoles are basically the same, but the pickup console has the rear A/C going though the console. The safe for the pickup that the competition makes for the PU is so small it wasn't worth making. The safe I wanted to build would replace the plastic tub rather than fit inside. This would allow for more storage volume. The bending process for making the compound shape is very difficult, and I have finally found a shop that will fabricate it. The prototype should be ready today or tomorrow and I will try to post photos.
Thanks,
Bobby Newell
RGNEWELL
RGNEWELL
Supporting Vendor
Delay should be over
Any updates on the yuke/hoe console safes?
This has been a monster to get right, no wonder no one makes one like it. I was out of state all last week, I will check on it today,
'Thanks
Kingfish585
Will any safe be made for the 05 Denali versions? No one makes them and I need a way to lock up valuables. There is absolutely no safe place to hide things in there.
RGNEWELL
RGNEWELL
Supporting Vendor
My LD2003 should work, but you will lose the 12 power port unless you drill a hole in the safe.
Sorry for the delay.
Bobby
tim j
