slowride77
'09 Tahoe. Front Diff pumpkin gasket was leaking and the pinion seal as well.
Pulled the front diff, replaced all gaskets and pinion seal and while there, replaced both axle seals (were not leaking before).
I was very careful, took my time, cleaned everything and reinstall per the book.
I had the passenger side axle seal leaking after about 500 miles (bad leak..puddle), so I pulled the half shaft carrier housing and axle, replaced again.
That side stopped for now, but now the drivers side is ever-so-slightly leaking. I runs down to the drain plug and one single drip on the floor.
I used all GM parts for the repairs, both times, but the seals were a newer part number replacement from GM that looked slightly different but were a dimensional match.
So....questions, Has anyone experienced this before? If i want the drip on the drivers side to stop, do i have to pull the whole diff again? Can you replace under the vehicle?
Also, these seals seem to grip the axle shaft and the rubber spins inside the metal clad shell vs the shaft spinning in the rubber...is that correct?
Was I an idiot for replacing something that wasnt leaking? I thought I was doing the right thing, but this is turning into an exercise in futility.
Any prior experiences would help! Thanks!
GM Part numbers:
22761722 axle seal
12471590 pinion seal
15270969 case seal
15270970 half shaft housing seal
GM Part numbers:
22761722 axle seal
15270969 case seal
