is this bad oil pressure idle
harry604
here is my oil pressure at idle when warmed up
is this to low ?
2012 yukon slt 5.3 152k miles
looks to be 19 psi
Welcome to the Forum from NH.
Pics of the truck, please.
That is a normal oil pressure for hot oil.
Marky Dissod
If your engine has V4 mode hardware (likely), parts of that subsystem may bleed off some oil pressure.
Disabling / shutting off V4 mode will not fix the underlying hardware issue.
Even given that, your oil pressure is on the low side of OK.
If you've any doubts, have your oil pressure checked, preferably by a mechanic
with a DIFFERENT SEPARATE physical gauge in a different spot.
balldaddy
