11 GM TAHOE W/Bose amp, aftermarket Jensen HU, PAC module
looking at the diagram it looks like it is only feeding the amp 4 channels and then lets the amp split it up with only left/right, no fade and no seperate bass level control
so.....
check your speakers and verify if they work or not.
was the factory radio harness still intact? or was it chopped off?
B
bakenator
I think I found the problem
Fixed it. The HU sounds good with input but the radio sucks. I think it will be upgraded to a better model. Now that I know it's an easy modification to fit deeper units in, it expands the availability greatly. Thanks everyone.
kevinsbritton
