2016 GMC Yukon
johnschaff2001
I was driving 75 mph with cruise on. All of a sudden the RPMs tac put and my speedometer went all the way up to 140. It automatically kicked the cruise off and it was like the vehicle was in neutral. This happened fir about 2 seconds and did not happen during the trip trying to mimick it. There did feel like some slight jerking in the transmission. No engine lights are on. Put it on the computer tland the only code was U0415. Any idea on what this could be?
Rygrego
Mission Viejo, California
This code is triggered when one or more modules on the CAN bus determine that the ABS module is sending out invalid data. The U0415 code can be caused by damaged wiring or poor connections, a bad ABS control module, or faulty ABS sensors.
Do you have a quality bi-directional scanner? That would give you additional information and most likely would point you to a specific area of the truck's systems to troubleshoot.
rick9667
