NiamLeeSin
- Joined
- Apr 19, 2023
- Posts
- 24
- Reaction score
- 15
Hi all,
I just purchased a used 2016 Yukon with 40k miles and HD tow package to be able to pull an 7500 GVWR RV trailer.
Due to all the "transmission failure" complaints here, I am worried about the transmission reliability on long trips and if it would be a good idea to upgrade the torque converter, or any specific components for heavy duty tow applications to avoid a catastrophic failure that would require a whole transmission swap.
I've weighed in to ensure it's well below the GVWR of the tow vehicle axles etc. It has no issues towing and performs very well.
I've also installed a Mishimoto transmission oil cooler and performed the Thermal Bypass Valve SB below and the transmission oil never goes above 190F even towing long distances or in stop and go traffic.
Here are some Performance Upgrades that look promising, but I don't know what I'm looking at. If anyone can advise on exactly what parts are known to fail and the best cost benefit or best preventative measure would be, if any at all, please advise.
www.sonnax.com
Upgrades performed thus far:
1. Cooler valve Thermal Bypass Valve service bulletin
Service Bulletin INFORMATION
w/ part number 86774933
2. Mishimoto Transmission Oil Cooler:
MMTC-K2-14
3. Range Technologies AFM disabler
Thanks in advance!
GM 6L80, 6L90 Performance Transmission Upgrades | Sonnax
Find top-quality 6L80, 6L90 performance transmission parts to enhance any build, from tuning pressure and restoring valve body function to ramping up shaft and clutch durability.
MMTC-K2-14
Thanks in advance!
