LordWayback
- Joined
- Jun 23, 2022
- Posts
- 558
- Reaction score
- 438
Spacers do do that I got the spacers to be a cool cat and they’re biting my butt the “cab” corner needs a small intervention with Mr sledgehammer and the grinder but Atleast they won’t refuse to align my truck for a while and I can drive it again with New control arms new idler arm and bracket pitman arm tie rods the back end needs the lift installed but that’s easy I do also need to either put the shock extensions or change to 2-4” lifted gas shocksfrom the blurry background it looks like the wheels and tires are too wide so not surprising
2” wheel spacers + new torsion keys within z spec no idea how cranked they are however it looks nice besides needing the rear coil spacersfrom the blurry background it looks like the wheels and tires are too wide so not surprising
265 60 r18 or 31~x 10.5”~ 2” wheel spacer +20? Offset 18x9.5 pro comp wheels max peeding rods torsion key lift minus the coil spacers and shock spacersWhat size wheels/tires?
They look fantastic on the sbox editionfrom the blurry background it looks like the wheels and tires are too wide so not surprising
