SnowDrifter
- Joined
- Sep 5, 2016
- Posts
- 2,405
- Reaction score
- 2,591
I appreciate the ideas, but I think we're really losing track of the goal here, which was recommendations for brands or ideas on how to make a high idle switch that would operate outside of any tuning - which is a bit cheesy. Unfortunately, any ideas for electric heaters are going to be pretty limited with a stock alternator at idle speed and won't really operate under enough power.
Running some quick math, I'm getting around 7kw output capability of the stock heater, with both front and rear on full blast. To do the equivalent on our 12v system, would need 540 amps of power. That would need 3 preferably 4 alternators to run the thing at idle - just not feasible.
Though now that I type this, I got another idea. I can set idle speed based on a/c on or off. Now I know the a/c won't operate below 36f, but what I don't know is how the vehicle handles the electronics and if that would cause it to go into that high idle mode without the compressor engaging? I don't want to force the compressor on at these temps to accomplish that. That's just asking for trouble as the refrigerant is apt to liquify and blowing up a compressor doesn't found fun.
Now, after some digging, I was able to find a pinout for the accelerator pedal. Can't find anything else on it though. Not really enough info be useful - not sure if it uses a potentiometer or a rotary encoder to sense position.
