Sasquatch
Orange County N.Y.
Any updates?
They bolted on with no problems, Now i just have to wait to see if they last any longer but i`m sure they will. Just be be safe i put a lot of red locktite on the stud because there`s no cotter pin hole.
The guy that did the alignment was shocked by how big they were and asked where i got them and is now getting some for his hummer.
mmeachem
Finally put my 20's back on after running my dipped stockers. New rubber and rotors all the way around. Ohstu St5000 285/50/20 and Powerstop Drilled Slotted in front and Blanks in the back. I painted them with High Temp semi gloss too.
TheAutumnWind
I have moog on mine right now and they`re the same size as OE. I only have 20 inch wheels on my yukon and they`re shot in about three years and around 18 to 20k miles.
Those are super expensive!
Guess its worth it if you save in labor or something. I'd rather replace the moogs a few times for less money.
Bowzer
SoCal
Brought her home from the shop today. Rebuilt trans, rebuilt transfer case w/ upgraded pump housing, u joints, new cats, new oxygen sensors, new rear AC expansion valve and new rear blower resistor pack. Ready for summer road trippin!
Output drum busted on the 4L60. I was told this is common and that I'm lucky it didn't crack the housing.
Got my Femco oil change valve today, now I have to wait till my next oil change to install it. Only 2500 miles to go ! Oh, and celebrated being named May's Truck Of The Month so I'm waiting on my detailing supplies gift from Trinova.IMG_5091.JPG
BADRIDES
How do the Ohtsu tires ride? Did they balance out easy. I see them on ebay and they are priced pretty right.
mmeachem
So far so good (knock on wood) they run smooth and quiet and held good on the highway in heavy rain.
TheAutumnWind
Finally got the replacement tow mirrors and put em on today. Also got a RC steering stabilizer today and put it on.
Hows the stabilizer feeling? I've got one that I have yet to install.
Truck is lookin good.
Go Raiders!
TheAutumnWind
Thanks bro, I'm about to give its first road test right now. Gonna go across town so I'll post later with results.
RN4L.
Awesome looking forward to hearing your thoughts.
Drtyhoe
Can anyone tell me if I can use an aftermarket sub in place of the factory one in my 02 Tahoe ? And if so any idea of one I can just swap out ?
Mike
pnwdan
Cunning linguist
Arlington, WA
Mike
There is a sticky in one of the other subforums about this and what people use
Mike
Looks like someone needs to learn how to use the search function! Yes there is lots of info on this, go find it!
ATIII
Brighton, CO (Denver)
Ok drove it for about 2hrs, all kinds of dirt roads to freeways & side streets. It really tightened up the little amount of play I had as far as in the wheel and doesn't pull when I hit ruts in my dirt road, but it still wanders around a little. Not so much pulling in either direction, just seems like it's right and left in the lane with small amounts of correction. Leads me to think it needs aligned again. Anybody have any thoughts?
Worth the $60 and about an hr to put it on, imo.
pnwdan
Cunning linguist
Arlington, WA
Mine did that after replacing everything and getting it aligned. New tires fixed it
TheAutumnWind
What kind of shape are your tie rods and pitman/idler arm in? I need to replace mine badly.
ATIII
Tie rods were replaced when I lifted it last September. They seem to be stout but I do think the arms might be next on the list. Anybody throw them expensive ass Rare Parts pitman & idler? Or should I just Moog 'em?
Merch619
