Administrator
Ordered timken hubs, a motor mount and new rear shocks for the 07
Bacovish
Took out my alpine and put in Dynaudio coponents. Also moved tweeter out of apillar down to the mid. Sounds much better. The mid is attached through the door panel to the door itself using angled brackets and spacer I made.
vinnyray
Lancaster, PA
I took 2" off. I wanted to keep the factory shape but make it shorter. I may try to mimic the Z71 and shorten the middle more.
tsuintx
DFW
Changed oil on my wife's Tahoe yesterday since the oil pressure had been dropping again below 40psi. Oil life monitor showed 24% left.
This was first oil change after putting a Wix filter and it lasted a whole lot longer than the Mobil 1 filter did earlier. Now I put Wix XP since it was the same price as the "regular" Wix. We'll see if that's any better.
The good thing was that there was no more metal flakes in the filter like there was last time around. Not sure if that was just a fluke that time, but it had me worried a bit. Or maybe what ever was wearing at that time is now completely worn and the motor will blow up soon. :eek: :D
NJ04HOE
Paterson, NJ
Wheel alignment is done and still rides good. The only thing left to do is the rear sway bar links that came with the rear hardware kit. Does anyone have tips on installing them and moving the sway bar? The instructions I found on the djm site doesn't seem all that straight forward to me for some reason.
Sarge
South Alabama
Tested the 4x4 for the first time in the yukon going down to a hunting camp. Did well with street tires, even though it kicked 90% of the mud on the running boards
SDHanz
