How many of you DO NOT experience buffetting and vibration problem?
BobDobalina
I have no issues with mine. 2015 LS 4wd. Early, early Feb 2014 Build. Just turned 21,000 miles. I had no issues with stock 18" Fuel Max tires and swapped to Bridgestone Revo 2 tires about 15K miles ago and no issues with those tires. I am very very very picky with any noises and can detect the faintest of driveline noise. I am curious what the noise is like. Is this issue present on any LS or SLE models?
Gdwheel
I have not had any issues. Tahoe LTZ January 2015 build, purchased in late-February 2015, 8,500 miles.
WYO-HD
I don't seem to have it either but have just had it now for about 800 miles. Bought it used with 19k and it is a March '14 build. Have the AFM turned off, corsa exhaust and 35" tires which may help from what I have read.
Cheers,
ssmblazer
I have a 2015 Yukon XL Denali, May 2015 build with OEM 22" wheels. I had absolutely no vibration problems until I changed my stock tires in Jan '16 to 22" Blizzaks. I have my own tire changer & wheel balancer. I didn't have the wheel balancer set to the most precise balancing when I made the change for the winter. The first drive after the tire change, the vibration was mostly unbearable around 73MPH. Anything below and it was fine. About 2 weeks later, I more carefully balanced the tires with the most precise setting for my machine. After the re-balance, the vibration would only occur above 76MPH and it was nowhere near as severe. Over the last couple months, the salt/road grime made the vibration severe again at around 72MPH. I just thoroughly cleaned the whole vehicle on Saturday and it went back to only a minor vibration above 75/76. I just took it to the dealer for the scheduled maintenance and had them balance the tires yesterday, and now there is absolutely no vibration at any speed. I have close to 24,000 miles on the Denali.
Chris T
I find it interesting so many people say they have no issues. Does that mean no BOOMING over low speed bumps/road imperctions? Vibration and buffetting are major and I agree, not all have it. Mine has a highway speed slight vibration due to the crappy Continental tires. However, every one I drove had the BOOMING at low speeds. Just wondering if others notice that.
WillieFlo
Houston, Tx
The only reason I have vibration at low speeds is because of the Nitto Trail Grappler MT's on mine. At higher speeds, smooth with the Mag Ride Susp.....
humer101
NJ,USA
35k +miles , 2015 XL Denali not buffering or booming here all good.
:cheers:
cardude2000
I haven't noticed booming in any of them that I've driven or driven in...the other stuff, absolutely. But not the booming. Not sure why...
68 Grand
Stock 2015i Tahoe LTZ 4WD, March 2015 build, with trailering package and 20 inch chromes. 11k miles and never had a thing resembling this.
Also briefly drove a rental 2016 Suburban with the same specs. No sign of this.
Flynnstone
I have a '15i Yukon SLE and had buffeting And vibrations when I bought it new. After replacing all the tires and road force balancing the problem went away.
I've since put 24" wheels on, and some minor vibrations and buffeting have come back. It's not bad enough to bother me, however I have had the new wheels road force balanced by discount tire and that certainly improved the condition. I'm pretty sure if I took it to a wheel specialist and had them road forced again/properly the buffeting/vibrations would disappear.
Shadow17
I do apologize but.. What is dod cam and AFM??
No problem. I am just very familiar with it coming out of a G8GT.
It is Active Fuel Management and Displacement on Demand. It is what causes the engine to cut out into 4 cylinder mode to save fuel costs.
In a Pontiac G8 with any serious engine mods, it was annoying as heck. One of the first mods recommended in the G8 forum was a tune to remove the AFM and keep it in 8 cylinder mode at all times.
Fuel mileage suffered. But the annoying vibration was gone.
cardude2000
How badly did mpg suffer?
Shadow17
I didn't drive my G8 much. Only 20K miles in 6 years.
I bought a module to eliminate AFM in my Yukon. I have only driven in town since plugging it in; no highway trips yet. I'm averaging 14-15 mpg on mostly 5-20 mile trips.
gat0r
DFW
no issue
early model 2015 burb ltz 4x4
MRC
towing pkg
aftermarket wheels
AFM disabled
sunroof
roof crossbars
cardude2000
no issue
MRC
towing pkg
aftermarket wheels
AFM disabled
sunroof
roof crossbars
Why did you disable AFM? And what was the mpg hit? Thanks
Cha0s13
I have Afm disabled on my Tahoe with a Range technology. I got sick of the horrible drone when v4 kicked in. I have not noticed any mileage change which is awesome. Drove to Orlando this weekend and got 24.2 Mpg.
sickk23
New Mexico
Interesting, thanks for the feedback! What is a range technology? And where can I get one lol
Conedaddy
