Post your lifts.
liftedtahoe
arkansas
Your just wanting the front lifted? Nothing done to the rear?
Sent from my SAMSUNG-SM-N910A using Tapatalk
massivespl
I'm not mean, I'm honest.
Michigan
Yea the rear looks lower then the front already. Get a 6" lift all the way around not just the front. That would looks silly
liftedtahoe
arkansas
I want 6 inches up front i don't mind it normal in the back because i want it to squat maybe 3in in the back at most
I'm with massivespl on this one for sure! I think it needs 6" all the way around
liftedtahoe
arkansas
That's my opinion though, but you can probably call up rough country or any lift supplier for that matter an order just a front lift
Antonio Estrada
Fort Worth Tx
3in spindles 3in keys ? Will give total of 6 up front and if i switch my air ride system to shocks n bigger springs ill be able to get 3 or 4 in the rear?
liftedtahoe
arkansas
Most the lift knuckles I have seen need diff drop brackets too because you upper control arm stays in its factory location, an just drops the lower control arm/ diff, if you got lift knuckles you front end would be in a bind, an you would go through bearings balljoints and axles
Antonio Estrada
Fort Worth Tx
So its better just to get my lift all around and use my keys on top to get it higher in the front it be the safest thing and reasonable thing to do?
liftedtahoe
arkansas
Only thing is I have 2" spacers on the rear of my black hoe and 1.5" spacers on my pewter one
liftedtahoe
arkansas
Alright i think ima do the 3in all around you have the link from witch you bout yours from?
I bought my kit off ebay, it's a zone performance body lift I can get you a item number if need be though
Conedaddy
