pin location for adding led mirrors
gibbygsxr
Kingston, NY
Just added led turn signals and thought I would share my findings. Couldn't find any direct info on this.
The cars are pre wired for turn signals as many of you know with the plug you have in the truck. Just needs a wire inserted into the empty spot. I had some left over pins from another project to use. It is pin 5 in the black plug coming from your current mirror. It is 12v+ and there is a larger gauge black wire you can use for ground off of the window switch.
The ones I got are like the one in the pic but mine have 9 leds
mr tahoe
NICE wish i saw your post before running wires through my truck and to the tail lights lol
SidewaystheSeven
What's the process to remove the existing mirror glass from the housing ?
Old thread bump, but I have the same question. How do you remove the glass?
Sent from my LG-H901 using Tapatalk
AppocAlexx
Darth Appocalexx
Abilene TX
All mirrors pop off, for the most part. If these are the same as the fords and older chevy vehicles I have done then it would be to push the mirrors as far up as u can then place as many of your fat little fingers under the mirror on the bottom and steadily pull up. Don't take my word 100 % but like I've said done it quite a few times on others and they all popped out with some good pullin. Good luck.
If you adjust it all the way out you can look in and see the tabs that snap it into place. There's 4 I believe and you can use your fingers or a flat head screwdriver.
Conedaddy
