Joew311
TX
Gave her a quick bath to get all the road grime off. Maybe I'm weird but that back glass all slicked up is the best part of having her all cleaned up.
Burbin
Senior Member
Clean windows are the best Can't stand for streaks
I personally think it looks great and would keep it like that @Joew311
Joew311
TX
Thanks guys! Im loving it! I can't believe how much difference that red all the way across makes.
Just got her back from the shop today. Got a new bumper cover painted and installed. Chrome tow hooks installed. Antenna colormatched. And all rock chips and dings on the front repaired.
Marioski
IL
Been chasing an oil leak that started as a slow drip and turned into a major puddle. I was able to see it dripping down the backside of the motor even at idle. Thought I ripped a rear crank seal but that wasn't it. Chased it to the top of the motor and took the intake off. Discovered the valley plate was leaking out of the drivers side rear area. Also found that none of the bolts holding the valley plate to the block were properly torqued down. As a matter fact, they were all finger tight which would explain the leaking seal. Decided to take this time and purchase the upgraded VLOM plate, (AFM engine) and now waiting for the new oil sensor (might as well) and intake manifold gaskets to come in so I can finish her up.
Found my leak and also looks like I had a critter living under the manifold at one point.
Original AFM VLOM plate compared to the upgraded version. From what I read, they have less oil bleed offs and it works better.
All cleaned up.
New VLOM plate installed. Ready for upper intake when seals arrive.
Used some blue locktite, torqued to specs and bolts marked. Now if they loosen up, I'll be able to tell.
MudnRox
Rebel without a clue
Olathe, Ks
I finally got the new tires I've been needing. I went with the Bridgestone Dueler H/L Alenzas in the stock size. Nothing like putting off a tire purchase until the middle of a big winter storm.
Jonah52
Senor ******
Cleveland
driven her about 350 miles the last day.... all highway 14.1mpg.... damn it sucks good thing fuel is cheap. Im on vacation with the family, then potentially snowmobiling and for sure working on a cj-5 project!
redeknightjr
Debadged, removed trim, removed resonator, added grill and tow hook overlays
Sent from my SM-N910P using Tapatalk
redeknightjr
Almosy forgot purchased and installed weathertech floor mats
Hodmjstone
