Tahoe Leaf Spring Replacement Installation
Phone Man
Long Island NY
Well after driving around with my sagging rear for a while, it was time to replace the worn out leaf springs. I figure I would give my experience and 2c. While it may seem an easy enough job to do, its always nice to have a little info before hand, so I wrote this up.
From my research there was a lot of talk about dropping the gas tank to get to the bolts and other discussions on leaf spring length. I have a 2dr and the tank did not have to drop. I have copied a size chart posted by Retorq in another discussion that is accurate. The 2dr needs a 54" spring.
The hardest part of this job is getting the old bolts out. You will need a good 1/2" breaker bar (my 3/8 broke), a small steel mallet, torque wrench and probably some heat such as a MAP gas torch. Also get some PB Blaster penetrating oil, WD-40 isn't going to cut it.
As far as ordering goes, good luck in finding free shipping, not gonna happen. Each one is around 70lbs and will cost about $100 for shipping so factor that into your cost. I got mine from General spring of Kansas City. They also were the only ones to have an HD version, 2200lbs instead of 1750. They were $129 each as apposed to $99 so I figured WTF and got the HD's. Link... http://www.generalspringkc.com/product_p/22-909hd.htm.
You will also need new Ubolts. Forget Ebay, get them from rockauto.com They are quality pieces. You may also want to get new shackles, one for each side. They come with 2 bolts and a bushing. You wont need the bushing since the spring already has it installed. You will however need a new bolt for the front of the spring so order 2 (one for each spring) when you order the springs. After you pound the hell out of the old bolts to free them from their rusted grasp, they will be useless.
Ok, so raise the back of the truck by the rear axle and support the truck by the frame on jack stands. Leave the jack under the axle. CHOCK YOUR FRONT WHEELS!
Start by removing the bolts from the spring's Ubolts and removing the top plate, bolts and bottom bracket. I ended up cleaning and painting the bracket and plate.
The top plate hole is chamfered to fit the bolt only one way.
Next, begin removing each bolt from the back and front of the spring. If you plan on replacing the shackles, and you should, then you only need to remove the bottom bolt. At least on the 2dr, you do not have to drop the tank. As you can see, if you have a factory hitch, there is a hole in the side large enough to fit the head of the bolt and slide out. The reason the bolts have the nut facing the outside is because in the future you may need to bash the bolt out with a hammer and you need room to swing. I was able to install the bolts the same way without an issue. It helps to have a large punch or a similar size bolt to hit it the rest of the way through the bushing. Mine fought their way out all the way home.
I ended up removing all the bolts and springs from each side (at this time you may want to clean and paint the parts). This left the rear hanging with the shock pressing down and making it twist a little. Not a big deal, you just have to muscle the rear into place after the springs are installed. I also added some grease to the bolts before sliding them into the bushings. Also if you install new shackles, install them on the spring first because you will not be able to put in the top bolt... you can tighten it later.
Phone Man
Phone Man
Long Island NY
Install all your bolts and tighten accordingly. The one thing I didn't like about the new shackles is that there was a lot of space between the bushing and the shackle steel. I tightened the bolt enough to close the gap a little without binding.
The ride overall is a little stiffer. Im thinking its because of the HD springs but the lazy bounce and sway is gone. Also the back raised a good inch at least. I have torsion keys in the front at the minimum and even with them, the back is a little higher. Overall, im happy with them.
Phone Man
Phone Man
Long Island NY
Update: These springs are stiff and ride a bit hard. They also raised the back around 1.5-2 inches.
Dneel81
OKC
Thanks for the write up. I'm doing a shackle flip to lose the lift blocks on my 2 door. If those old-arse pansie springs don't stop axle wrapping and farking up my pinion angle/geometry/crap after the flip, I'll get some beefier springs. Appreciate the parts chart.
DN
moviewithnotitle
Jersey
Phone Man,
Can you explain this statement a little further: "The ride overall is a little stiffer. Im thinking its because of the HD springs but the lazy bounce and sway is gone."
I'm particularly interested in the mention of "Sway". I have similar issue where the rear-end tends to gently sway/drift side-to-side while on the highway. I'm not concerned for my safety...YET...but it's a growing problem in the last few years and I would like to try and correct it. I've been thinking it might be bushings (my 96 still has the original bushing on the leafs).
Your thoughts?
Dneel81
OKC
Phone,
I'm trying to figure out if I need new springs. I've ditched the lift blocks in my truck, done a shackle flip in the truck with a zero rate. My axle wrap is still awful and shows its head by a bad acceleration vibration. I'm trying to figure out if I need a CV joint or if my springs are just shot. Your setup looks stock. Any experience with axle wrap on your rig before/after the spring swap?
Thank you
DNeel
SunlitComet
OBS Jedi-Do Good
unknown at this time.
post some side shots of whole vehicle as well as wheel areas as well as ones looking forward and backward from on the ground to visualize the under-body.
Dneel81
OKC
SLC,
I've already torn into the front end rebuild but here are some pictures nonetheless. Luckily I snapped one of her stance before I cut up her front end...God please forgive me for still running those ridiculous wheels. Waiting to pull the trigger on some MT Classic IIIs.
SunlitComet
OBS Jedi-Do Good
well the springs have some good arc. however if the add a leafs are creating it or you get wrapped with the current setup then they are not as good as they can be. it looks like the second leaf from the bottom might be creating the arc. the rear is a little low as well. they have a stock rake to them.
Dneel81
OKC
you mean the springs are a little flat? And it appears from the online pictures I've seen that there is an add a leaf in the pack, no? Thanks SLC
SunlitComet
OBS Jedi-Do Good
yeah i think the two adders at the bottom are hiding the issue. well the second from the bottom anyway. but yes you have two extra and you have the 4leaf oem. there is a 5 leaf oem as well.
Dneel81
OKC
that sounds about right. Previous owner cut corners and half-assed more and more stuff on this truck... the more I work the more I find. Looks like I'll be replacing them also soon... Thanks.
Dneel81
OKC
No way SLC. I would think yours would be pristine. no?
Dneel81
OKC
so this being the add a leaf spring (see yellow line below). It needs to be up under the 2nd spring in the pack? Doesn't seem like it's doing jack squat right now. Seem reasonable? Or just take it out...
SunlitComet
OBS Jedi-Do Good
it is fine where it is at it is doing its job so to speak and it adds to the overall height. unfortunately it also might be hiding the effect of old spring packs. if the spring pack has the same or less arc when it is removed from the vehicle then you know for sure they are bad.
SunlitComet
OBS Jedi-Do Good
unfortunately not. do to illness twice in the last year i am out of work with no money for repairs or upgrades and things to get done have falling behind for sometime now. even the registration is six months expired so you can imagine the difficulty i am having trying to make this suv a beast to be reckoned with.
Dneel81
OKC
I'm sorry to hear that man. You should start charging for your good advice on here...
brice715
