Esky taillights
luigasca
luigasca
Man that's a lot of red...
Consider tinting them a little?
Yup. That's the plan I said the same thing to much red. Planning on adding just a little bit of dark to that clear plastic.
Sent from my SAMSUNG-SM-N910A using Tapatalk
NathanJax
Vacation Nathan
Jax, Fl
luigasca
luigasca
Can you send some pictures of the lights when they are on? brake, turn etc.
how was the install? was it plug and play?
What about the quality?
thanks
luigasca
luigasca
thanks
Quality on the lights 10 out of 10. Install was about 2 hours just because I wanted to be careful so there wouldn't be any scratches or broken tabs on my truck. Yup just plug and play.
luigasca
luigasca
I want a set of these so bad!
You need to get them I recommend them.
---------- Post added at 04:40 AM ---------- Previous post was at 04:39 AM ----------
I think they look pretty awesome.
That's what everyone tells me when they see them around my area..
---------- Post added at 04:41 AM ---------- Previous post was at 04:40 AM ----------
thanks
I'll post some more pictures later. Just haven't had time to take more pics.
SteveMansur
Gmc Yukon escalade taillights
Will these lights fit on the gmc yukon? And do they require any modification at all or just purely plug and play?
luigasca
luigasca
Yes if you have the 2015 yukon definitely. That's what I put them on 2015 GMC Yukon. It's all plug n play.
---------- Post added at 12:13 AM ---------- Previous post was at 12:07 AM ----------
What I like about these is that they don't have the caddillac symbol inside the light. So it makes it look like they go with the Yukon...
Shadow17
Here's a little preview on a tahoe and I think it looks clean.. I think on the yukon they will look alot better lol. Watch "2015 suburban rear escalade light conversion." on YouTube
[yt]SVSsEw9OM7k[/yt]
That thing has new taillights yet has those wheels?! :jester:
luigasca
luigasca
Lol.
---------- Post added at 04:04 AM ---------- Previous post was at 03:55 AM ----------
FIRST YUKON WITH THESE TAILLIGHTS...
SteveMansur
They look amazing, thing is they arent available on ebay anymore so do you know if the oem escalade lights would fit properly? Also, how reliable are these lights because i have a full led conversion on all exterior bulbs and my low beams are flickering after 4 months (warranty replacements on the way).
NathanJax
Vacation Nathan
Jax, Fl
Yes they would fit, but you'd have to do some rewiring due to them being full LEDs. Personally, I'd wait till they get back on eBay
Considering he's basically the first with them, no idea on reliability. However, if they're made by the same people who did all the 07-14 replacements, I'm sure they'll be fine.
luigasca
luigasca
The escalade lights will need some modification. The lights will fit but you will need 4 resistors and will need tap into some of the wiring or possibly need a new harness. These lights are exactly like the escalades. Only difference is that these don't have a caddillac sign inside of the light(more like they came stock)
---------- Post added at 10:23 PM ---------- Previous post was at 10:21 PM ----------
They look pretty reliable to me lol. We will have to see. Only time can tell. Lol
---------- Post added at 10:26 PM ---------- Previous post was at 10:23 PM ----------
These come with 5k reverse lights. Clear turning signal (when turning they turn amber). Today if I have some time I will post a video of my set up. And it work with my remote start like if it was factory.
bourgeois
luigasca ,
I am not sure on how to remove the tail lights. Can you give me some advice? thanks
luigasca
luigasca
luigasca ,
start by removing 4 plastic pieces they are held by clips (remove gently) the top plastic is held by 1 screw
Begin removing the top piece held by 3 screws and clips on the side. The light is held by only 2 screws and 3 clips also (be gentle with the clips)
After everything is removed then just repeat the steps just take your time and everything will be ok. Quick tip if you get the lights I bought you will need to remove the factory harness.
The lights come with a harness and plugs right in. The plug you will be plugging into is at the bottom of the rear bumper.
cdhpc2
