Goodinblack
I Like Tacos
New Volvo look nice
Sent from my SM-N910V using Tapatalk
Yup. That's the plan I said the same thing to much red. Planning on adding just a little bit of dark to that clear plastic.Man that's a lot of red...
Consider tinting them a little?
Sent from my SAMSUNG-SM-N910A using Tapatalk
Quality on the lights 10 out of 10. Install was about 2 hours just because I wanted to be careful so there wouldn't be any scratches or broken tabs on my truck. Yup just plug and play.Can you send some pictures of the lights when they are on? brake, turn etc.
how was the install? was it plug and play?
What about the quality?
thanks
You need to get them I recommend them.I want a set of these so bad!
That's what everyone tells me when they see them around my area..I think they look pretty awesome.
I'll post some more pictures later. Just haven't had time to take more pics.Can you send some pictures of the lights when they are on? brake, turn etc.
thanks
Yes if you have the 2015 yukon definitely. That's what I put them on 2015 GMC Yukon. It's all plug n play.Will these lights fit on the gmc yukon? And do they require any modification at all or just purely plug and play?
What I like about these is that they don't have the caddillac symbol inside the light. So it makes it look like they go with the Yukon...Will these lights fit on the gmc yukon? And do they require any modification at all or just purely plug and play?
Here's a little preview on a tahoe and I think it looks clean.. I think on the yukon they will look alot better lol. Watch "2015 suburban rear escalade light conversion." on YouTube
[yt]SVSsEw9OM7k[/yt]
Lol.That thing has new taillights yet has those wheels?!![]()
They look amazing, thing is they arent available on ebay anymore so do you know if the oem escalade lights would fit properly?
Also, how reliable are these lights because i have a full led conversion on all exterior bulbs and my low beams are flickering after 4 months (warranty replacements on the way).
The escalade lights will need some modification. The lights will fit but you will need 4 resistors and will need tap into some of the wiring or possibly need a new harness. These lights are exactly like the escalades. Only difference is that these don't have a caddillac sign inside of the light(more like they came stock)They look amazing, thing is they arent available on ebay anymore so do you know if the oem escalade lights would fit properly? Also, how reliable are these lights because i have a full led conversion on all exterior bulbs and my low beams are flickering after 4 months (warranty replacements on the way).
They look pretty reliable to me lol. We will have to see. Only time can tell. LolYes they would fit, but you'd have to do some rewiring due to them being full LEDs. Personally, I'd wait till they get back on eBay
Considering he's basically the first with them, no idea on reliability. However, if they're made by the same people who did all the 07-14 replacements, I'm sure they'll be fine.
These come with 5k reverse lights. Clear turning signal (when turning they turn amber). Today if I have some time I will post a video of my set up. And it work with my remote start like if it was factory.They look amazing, thing is they arent available on ebay anymore so do you know if the oem escalade lights would fit properly? Also, how reliable are these lights because i have a full led conversion on all exterior bulbs and my low beams are flickering after 4 months (warranty replacements on the way).
luigasca ,
I am not sure on how to remove the tail lights. Can you give me some advice? thanks
