My new to me Tahoe
Mudfrog
Mudfrog
I'm really concerned that a 2 - 2.5" level will not be enough to clear the 285 70 17 Zeon LTZ. Can anyone comment? I really do not want to trim.
32.8 x 11.2 on a 17x 9 wheel
Mudfrog
Mudfrog
Here's the updated pics. I went with a 2.5" level in front, Z71 springs and a 1.5" spacer in the back. I installed Bilstein 5100's and a KYB steering stabalizer. To the top of the fender it now sits 39" in front and 40" in rear.
The wheels are Raceline Raptors 17x9, the tires are Cooper Discover AT3 in 285/70R17 10 ply.
Nice job. It's amazing what a little TLC does to these rigs. Or a lot in your case- I'm impressed with what you did to the undercarriage. It makes me glad that salt isn't used here in the PNW.
Mudfrog
Mudfrog
The rust is starting to show up again so I'll have to grind and paint the undercarriage again. I think I need to apply more coats this time. Last time I only did a couple.
Black4x4
Is it a 4x4? I have an 02 and used to run 285/75/16s stock before the lift with no rubbing.
Mudfrog
Mudfrog
I love my cooper At3's. great choice in tires.
So far they have been a good tire. Great traction on wet pavement.
---------- Post added at 11:07 AM ---------- Previous post was at 11:06 AM ----------
Yea it's a 4x4. I'm running a 9" wide wheel, it doesn't rub though.
Mudfrog
Mudfrog
So how about an update. I've had 3 transmissions put in. The first two the pump broke within a couple thousands miles. He must be using a cheap pump, going to sell it on craigs list, as is. After the second time the pump went out, I bought a reman from Auto Zone which had a 3 year unlimited mile warranty (including labor). It lasted 100 miles and was burnt completely up. Sadly the labor rate that they cover is only $50 an hour, so I had yet another $500 in additional labor, fluids, etc.
Anyway, so far so good on the second replacement from Auto Zone.
Mudfrog
Mudfrog
Thanks man.
I think I'm going to switch up my exhaust soon. I'm not happy with the dual exhaust, going to go back to a single 3" tailpipe.
vtxtexan
