Washed her up tonight
08grey
Noticed my inner side of my front rotors is getting a brake build up. Any idea what causes this? Is it just heat? uploadfromtaptalk1439087837704.jpg
Fir_Na_Tine
Not today but earlier this week took 07 Tahoe to get new interior door handles because of the peeling issue. Dealer replaced without any problems. I think I'll get oil changed there as well now since I tried to do it today and found the drain plug is rounded off. First oil change since I got it earlier this year.
farhanm
Oklahoma City
i didnt really pay attention to it. is that a cause for concern? this was the first time i was doing any mechanical work ever, on a car.
08grey
It's common on these trucks. Krp makes a bracket that I used that works great. Get in there and take a look. It ultimately means you have a exhaust leak.
You've never done mechanical work on a car and a valve cover gasket is what you used to be your first experience? I'm impressed!! Most would be intimidated by that :Handshake:
farhanm
Oklahoma City
Thanks... i spent quite some time going through videos before i attempted. Special Thanks to Kysrsze for This
---------- Post added at 09:44 PM ---------- Previous post was at 09:41 PM ----------
btw from the pictures can you pin point/indicate the bolt you suspect could be broken off one?
Thanks
Farhan
06yukon619
Finally got my torsion keys and Bilstein shocks installed.
devious1
Orange County
Wasn't to bad. Took some fishing line,went behind the tab and slowly went back and forth until it came off. Used Goo Gone and a razor to get the rest of the glue off.
@bigrhino - that doesn't sound bad at all. i thought i would have to put a heat gun to it for quite some time and basically pry it off. thanks for the reply, looks like i might be tackling this later today. :)
d-alex-l
No pun intended huh?
---------- Post added at 02:09 PM ---------- Previous post was at 02:09 PM ----------
Changed out the door speakers and upgraded to the Kickers. Massive difference in the highs and lows.
devious1
Orange County
are you running a oem or aftermarket HU? i need some advice on a mild upgrade from the bose system
Merch619
