Post your setups!!
jerryjoe28
That Guy
cabot AR
ba ha ha save gas! i have no idea what my mpgs are but its not good! oddly my rpms are a little lower on mine at 70 but i rarely ever get on the interstate so i dont care
lonnel26
Auburn Hills, Michigan
Currently on the truck 20 inch rims... truck is in the shop so I can't give you the exact.. But mostly highway driving but I do drive around the city from time to time.
bowtiefreak
bowtiefreak
No Quarter
Near Philly
Both my trucks have 4.56 and a trutrac. The tahoe feels good but I wish the suburban had 4.88 because of the weight.
noJeepshere
Bountyfull, Utahrd
What kind of fuel mileage you getting from both? I'm doing an axle swap to one tons with 4.56 gears and 34" tires and would like to get a ballpark on numbers. Thanks.
cent frum a smaert fone
mattss90
Kingsburg, California
I added 4.56 with tuetrac. But Idk if I'd quite recommend 4.56 for commuting on the highway and stuff. My hoe now runs 700rpms higher at 70mph than it did with the 3.73. Maybe go midway with 4.11. Just my thought. But I do love the 4.56 for driving around town or driving up into the mountains. Lots of torque. Especially when rolling around in 2nd gear. :party52:
But my mileage is running around 10-11mpg Really no matter how I drive it. But definitely don't leave the 3.73 in there if bigger tires and lift are put on.
bowtiefreak
bowtiefreak
No Quarter
Near Philly
If you have 3.73 now with a stockish tire and then run 35s, the 4.56 gears should get you back around the stock feel.
bowtiefreak
bowtiefreak
No Quarter
Near Philly
I'm just here to give advice. My suburban has 35s and 4.56 gears. I am pissed I did not go with 4.88. Do as you feel and cross reference what I say on any other full size forum, the answer will remain the same
jerryjoe28
That Guy
cabot AR
x2 any full size forum will tell you 4.56s with 35s
roy72004
Hey y'all, it's the new guy. 98 Tahoe, don't remember height measurements, but it's about 9". (Comparison from a stock one in a used lot.) Solid axle swap with 35-12.5/18.
Sent from my SM-G920V using Tapatalk
noJeepshere
Bountyfull, Utahrd
Nice ride, though I am a bit partial to axle swapped Tahoes/Yukons.
ORD axle swap with 2" tuff country ezrides, Dana 60, ORD crossover steering, rear shackle flip from ORD, stock springs, GM corporate 14 bolt with factory discs and gov-lock, transfer case swap and 295/70-17 tires.
sent from a slablet
vsaravia
