Battery Terminal Problem
Sentry
Ok, so I have continually drained an Optima Red Top. I recently purchased a Optima Yellow top.
I went to move the truck the other day and the yellow top was dead. I can say I may have left the passenger door open for about a week. That may be the culpret on this one.
However, an issue I am experiencing is when I attempt to tighten the positive terminal is slips and I have to re tighten it with the same result. I can see that the positive connections are not compressing.
I looked at the threads on the battery and they seem fine, so I am thinking the problem is more the threads on the cable terminal.
What are some side post terminals I may want to look at? Better than average?
In the near future I want to change to top post, but Im not there yet.. I imagine I will need longer wires for that, and I am not even really sure to start with that as well.
Suggestions for correcting the current side post issue and upgrading to the future top post would be greatly appreciated.....
TheAutumnWind
you left the door open for a week and your truck is still there? Where is this magical place?
Mine would be stripped on the side of the road somewhere...
S
Sentry
It was cracked. No magic. However in the back yard and locked none the less... A kid closed it...
ccapehartusarmyINF.(ret)
Gilbert AZ
i have a similar problem with my red top my negative terminal tends to loosen up over time about every 3 to 4 months all the sudden ill be somewhere and try to start it up and nothing when i turn the key and it only loosens a little bit so i gotta bust out the socket wrennch and tighten it like 2 turns and it cranks up on the first try
SunlitComet
OBS Jedi-Do Good
unknown at this time.
terminal bolts are supposed to be sacrificial. just try anything for now to allow for further diagnostics on undeadening your batts.
Boomintahoe
sidemount terminals ftl...
Gotta love top mount. Much more easier to deal with.
veteran111
