Who has changed their 3.08 gears?
Tmg115
Fort Worth, TX
I have a 2014 Tahoe PPV with 3.08 gears. I am thinking about changing them out to 3.42 or 3.73's.
I am looking for a little quicker acceleration from a stop. I do not race my Tahoe but it is a slug accelerating from a stop light. I feel like I have to mash the gas peddle just to get it to move. I do not tow with it. I am just looking for better drive-ability.
Has anyone done this? If so how did it affect acceleration? Also how bad did it affect MPG's? What RPM's are you running at 80mph? Did you need anything other than the ring and pinion? Also how did you change the ecm for the gears? Will a tech II handle that?
I am not looking for a tuner at the moment. I still have 3 years on my power train warranty and I do not want to void it. After my warranty is up I will look into a tune.
14SWTahoe
Tampa FL
Im pretty sure the 6spd Tahoe's came with 3.42 gears where the 4spd came with 3.73, very rarely did the 4spd come with 3.08.
PPV I believe always had whatever was standard for that trans and year.
T
Tmg115
Fort Worth, TX
Towards the end they put mostly 3.08's in the rear end. I confirmed I have 3.08's on my window sticker.
M3kanic
I want to change out my 3.08 as well.
Sent from my SM-G900V using Tapatalk
jetmech
I don't even know why the put such a high gear in a vehicle this size. My wife's 2011 Tahoe has 3.08's and it really needs a 3.23 minimum. The 6L80E has such a deep overdrive, there's no reason to run such a high ratio.
aflumb
Las Vegas
I agree. this is something i have been thinking about doing also
Clean07Burb
My Suburban has 3.73 gears and I feel it could use more power. I couldn't imagine having 3.08's. That'd be terrible.
Sparrer
New Jersey
Picked up a 2012 Tahoe LT a few years back to replace my 2001 Silverado 1500 (RIP Truck). In my haste to get a vehicle I made some compromises biggest being the HD towing package. My Silverado had 4.10 gears and could pull down a house, the Tahoe has 3.08 gears and cant get out of its own way. So needless to say a gear swap is in the near future. My old man has a 2012 Suburban LTZ with 3.42 gears which I think are OK but still leave me wanting more specially when pulling a trailer. I was thinking about going with 4.10's like the Silverado but with first gear in the 6L80 being 4.03 I didn't want to get too aggressive. So I am thinking 3.73 gears are the way to go, do you guys think they will be over kill?
fiatdale
Houstons Best
Houston
3.08 with the 6 speed isn't terrible. 1st gear is like having 4.10s. They do it for one reason - mileage. I'm about to change mine in the truck to 4.56s, but Im lifted on 35s. Still would rather have the 4 speed though.
jz57
Take a look at your Tahoe's glove box cover, the build sheet shout be there. Most Tahoe PPV has GT4, 3.73 gear ratio and G80 LIMITED SLIP differential gear.
K2 Kaiju
The Depths
Super old thread, but I changed my gears on my 2011 2wd LS from 3.08 to 3.42 to tow my boat (I also added a truetrac LSD). The final drive on the 6speed/3.42 is lower than 4speed/4.10 combo (13.8 vs. 12.5), so for stock tires 3.42 is plenty for jerking out a boat...
Having driven both - I think the 3.08s are not as bad as people make them out to be. I actually might like the 3.08 1st gear (12.4) a tiny bit better for regular street driving (it is almost exactly what the 4.10s are with the 4 speed: 12.5) because the shift wasn't as quick to second allowing you to get up a little more speed before the shift. The problem is the gap between 1st and 2nd and throttle response/torque management. I you reset ECM and drive full throttle everywhere for a few days, you will notice a better response as your engine "learns" your driving style; a tune fixes both issues instantly which is why people feel such an improvement without a gear swap. I did notice about a 25 mile drop per tank after I switched to 3.42s. I wouldn't do 3.73 on stock tires...
thirdcoast
Victoria, Texas
Specs on PPV from GM
2016 TAHOE 2WD POLICE PACKAGE 9C1
. E85 is 85% ethanol and 15% gasoline. STANDARD 9C1 CHASSIS FEATURES AIR CLEANER High-capacity ALTERNATOR 170-amp high output with idle boost based on battery energy level (see specifications page for description) AXLE 3.08 Ratio with heavy-duty locking differential.
I suspect they do this to get the higher MPH with the stock engine.. PPV's never tow that I know of so don't need the lower gear.
As far as towing, with the newer vehicles, 4.10:1 might be fine with the .67 OD, but in my 07 Sierra with the Max Towing Package, I have 3.73:1 gears with the 4L70 Tranny. I pull up to 10K occasionally and 6-8K on a regular basis. Does well and gets 10-12 MPG at 70 with the 6-8K load. 130,000 miles and never had a problem with it..
TC
Ryno21
With the 6-speed I don't think I'd go above 3.73. I own a Sierra with the 4 speed and 3.73, tows pretty well if you don't tow anything huge. 3.43 would probably be ok. I also have a Tahoe with 3.73 rear and the 6.0/6l90 combo from a suburban. Tows like a beast. I'd say first gear is a little too low for a daily driver, but it gets off the line quickly.
It all depends on what you're looking for.
brice715
