shakedown067
Got the drop kit installed friday night after the parts arrived at the shop thursday afternoon. Pic below is at 12 am on the way home. 2/3 McGaughys kit with spindles and springs. Although it looks more like a 2/5. Going to make a 1.5" spacer for the rear later this week, or I'm going to adjust the torsion bars to lower the front a bit. Rides damn nice though.
Red_Raider
Derby, Kansas
Nope it's a LS model.
Fixed the fuel spray with some new o rings. I also changed the oil and air filter on the wife's NNBS Sierra. I decided to paint the tired looking drums black. Definitely a nice change.
05Yukon23
Arkdelphia, AR
Front spindles, rear springs, ujoints, front UCAs, LCA bushings and ball joints, put factory torsion keys back in, front sway bar end links, ordered rear DJM links, ordered cowl hood, did the free travel mod, new bump stops, cut the tail pipe off and dumped before axle, greased everything, and changed the oil.
TheAutumnWind
Replaced front rotors and pads. The pads weren't all that worn but the rotors were warped but good.
Confirmed that my '05 GMC Yukon 2500 SLT with 496 8.1 does indeed have an Air-Ride suspension though it has never functioned since I've owned the vehicle. Consensus on the forum seems to be that I should keep the Air-Ride and repair it rather than replace. Looks like Arnott will be getting $800 bucks soon.
I deleted mine. Much happier. 1/4 the price is nice too.
Brake_L8
Alexandria, VA
I replaced one of the two lines that run from the Hydroboost unit to the power steering. Was able to easily replace the line that goes from Hydroboost to steering box. The line that goes from Hydroboost to the P/S pump seems near impossible to remove without undoing the P/S pump and everything surrounding it, which I didn't feel like doing quite yet. Gonna post up another thread to try and get some tips on that, as I have to think it's possible to do without all the removal of everything else.
Mudfrog
Dropped it off at the shop. They are replacing the rusted brake lines and installing a leveling kit.
jcevans7
Friendswood, TX
Hate to sound like a dumb ass but can you take a pic of the hydroboost. Can't tell if I have one in my 03 denali
Sent from my SM-N910T using Tapatalk
1clean08denali
Removed the roof rack off my denali
YukonXL04
The Riverboat
Arlington, TX
Here is the difference between the Hydro boost on the left, and a normal brake booster on the right
jcevans7
Friendswood, TX
Wanted to change the front rotors and pads out didn't have a hex bit couldn't get a Alan key to work so I bleed the brakes and rotated tires. Upon getting to the rear tires found this gem waiting. So she staying parked till I get some new rotors for the rear too.
wwiizz
