P0011 code on 2007 yukon 6.2l
tazjamin
Casa Grande, Az
Ok so i got this p0011 code again and I already replaced the cam sensor on it and it is back again the other codes i have are lean bank 1&2 which im guessing that might be vacuum leak but now since the p0011 code is back could this all be related and does anyone have any ideas as to where to start? It also has 200,000 miles and after I changed the cam sensor when going long distances about 75-80 mph the cam adjusts and the lifters start knocking i was about to buy new lifters and cam which would have changed all the gaskets that could have possibly be my vacuum leak but now with this code back on im going to wait to see what this possible could be thanks for the help
tazjamin
tazjamin
Casa Grande, Az
Could this be my cam actuator solenoid going bad? Ive never messed with this new style of cam adjustments
08grey
Cam phaser. Maybe. Just found out mine was the cause of my engine noise
tazjamin
tazjamin
Casa Grande, Az
What is the cam phaser
---------- Post added at 09:20 PM ---------- Previous post was at 09:18 PM ----------
I just ordered cam valve thinking that could be part of the problem
---------- Post added at 09:48 PM ---------- Previous post was at 09:20 PM ----------
I know what the cam phaser is now i just never heard it called that yet as im still new into this vvt stuff lol but yes i was thinking of getting that also now since i found out the valve also acts as a bolt for the phaser im might as well replace them both. But im also trying to figure out where i can get a new solenoid for the cam as when i had to take the timing cover off to get the cam position sensor out i took the solenoid off and cleaned all the build up off of it so im wondering if that could be part of the issue also
08grey
Yes. The selenoid from what i have read so far is not reusable it has to be replaced every time you remove it. Something about the way it's torqued that locks it's position. It says you finger tighten it, then tighten to 45lbs then use a angle measure and turn it another 90 degrees. I have the replacement instructions somewhere. I had a thread months ago asking about the engine noise. If you can find it you can compare your noise to mine.
tazjamin
tazjamin
Casa Grande, Az
I tried searching for engine noise and looking through your replies but there are so many i cant find it
tazjamin
tazjamin
Casa Grande, Az
Ok so this is what im thinking of doing, im going to replace the valve, actuator and magnet and while im there replace intake gaskets and the lifter oil filter since it has 200,000 on the engine i don't think i need to do the cam and lifters now but who knows after i do this all and im not sure about the oil pump and timing chain if im going to replace those i dont want to remove engine and dont know what all i can take off while still in
JML07denali
I have the same exact code popping up. Do you know the part number for the cam actuator solenoid "cam phaser"?. I just bought the cam sensor (haven't installed it yet).
08grey
I gotta do this also keep it updated please. If in can be any help let me know.
ddubdb3
for the p0011 try changing your engine oil first and make sure your new oil level is topped off. for your lean codes take a look at your mass air flow sensor..
tazjamin
tazjamin
Casa Grande, Az
Been there done that and also switched cam sensor
JML07denali
Spent 1.5 hours trying to get to this damn bolt to remove the metal guard. (It's the silver one on the top behind the pulley) tried a open wrench but no room to reach from under or over. Tried a socket wrench but the socket was too too long and wouldn't clear the pulley!!![emoji35][emoji35][emoji35]
I was able to remove the others.
But unless you take off the one behind the main pulley the shield will not move far enough to remove the sensor! From the looks of things I need to remove the water pump just to get access. Has anyone else had this issue? Probably going to breakdown and have a local shop change it.
tazjamin
tazjamin
Casa Grande, Az
I believe i went through the balancer to remove it, also one thing that happened to me was the sensor was so fragile from heat the it just crumbled on me and i ended up taking the timing cover off to pull it out thats when I learned that ls engines need some special tools that I didn't have at the time like a 3 jaw pulley for the harmonic balancer and to put it back on you need a special tool for ls engines which i bought one off of summit racing but at the time i had to make my own with auto zone rent a tool and some threaded rod from home depot and had to cut the threads on the rod from course to fin which didn't leave much thread left but it did work it was a mess when all i was trying to do was that sensor so beware it could take much longer than expected and like me once i went too far that was it i was in until it was finished which took two days and that was my only ride
tazjamin
tazjamin
Casa Grande, Az
I just used a couple extensions and socket to fit through that hole
JML07denali
Man, I tried and tried but could not get the socket over the nut since the balancer was too close the the nut?
tazjamin
tazjamin
Casa Grande, Az
Im not sure exactly then i might have used a open end wrench to get it
JML07denali
Broke down and took it in to a local shop a few blocks from my house. $100 out the door. Let's hope p0011 stays away.
Candielaine
