chaingun427
OBS Mad Scientist
Mooreland, OK
Got the bubbles cleaned up and primed in the rear floor board, might have a line on an ls engine a well for that swap
Gzes
the drifting 2dr
Wichita tx
Finally did the blend door actuator. Holy crap that was annoying. Still gotta do egr and oil cooler lines
chaingun427
OBS Mad Scientist
Mooreland, OK
Mopped up more water from the back. Apparently there is a recall on the barn door seal and I'll need to buy a new one
omaha
Got my exhaust done again. Got rid of both the cats and did straight 2.5 pipes all the way back with 4x18 tips. That was too loud so I had him put an H pipe in and now im satisfied! The rumble it has during idle makes me wet myself
:naughty:
neosoul
Las Vegas
finally got my spider injector replaced, along with new cap and rotor, fresh antifreeze, new synthetic blend engine oil. next up will be a new starter
bigal11419
Queens, NY
Changed the oil and oil filter, replaced headlight assemblies and parking lights. Swapped out corner lights and reverse lights for leds. Replaced weather stripping on liftgate, rerouted wiring for the reverse camera and replaced the wiper blades.
Gzes
the drifting 2dr
Wichita tx
Still waiting on busy to finish ac.. he's been having a problem with the orfice tube. Looks like the line is a little bent so the tube won't fit. Broke an expensive one I bought too..
noJeepshere
Bountyfull, Utahrd
Nothing to see atm, it's all internal right now, but when I get it open in the next few weeks after the swap is done I'll crack open the diff and see what's what.
cent frum a smaert fone
_Dylan_
STAY FROSTY
Been working on the a/c system this week.
The lower connection on the condenser was seized and I ended up twisting the line on it and kinking it. Yay, new condenser and a/c line too. Good thing is parts for this turd are cheap and it seems to be holding a vacuum just fine. I'm into it for about $350 so far including the gauges and vac pump.
I forgot my only set of keys for my truck in my boss's truck, so I couldn't start it and put the r152 in. I'll do that tomorrow after I put the vacuum on it for an hour. :)
Gzes
the drifting 2dr
Wichita tx
Hey that's what happened to my 2dr. Where the orfice tube goes it kinked so we had hell trying to get it to work ealrier. Broke 2 orfice tube but finally got it fixed and in and mostly bolted up
chaingun427
OBS Mad Scientist
Mooreland, OK
A.c. systems suck. My buddy doesn't understand why I'm fighting so hard to leave the front clip together on my project lol.
On that front, I finally got the engine and transmission split, and I'm waiting for a clear day to start scrubbing them down. And recommendations for the nv4500 and np241 as far as a cleaner/mud remover so I can paint them?
Hodmjstone
