Deephaven
She runs!
Deephaven
Got the tune iterations all ready for a WOT pass tomorrow.
I'll share details later, right now I am focused on making sure she is all buttoned up.
Deephaven
First WOT run. Just to 3rd gear. A bit fat on gas atm, but next tune iteration ought to get that much closer.
Deephaven
It has its own water pump and radiator. It's are around 65 or so in my early testing
tsuintx
DFW
AC belt tensioner started to make helluva noise while cold a few weeks ago, so went ahead and changed it and both belts. Nice and quiet once again.
Once I was done and went to start, it only clicked. Has done it a couple of times before, too, but still started after a couple of tries. Has new battery/alternator and the cables are tight, so the only thing left is the starter, so I crawled back under there and noticed that the cables were slightly loose. Tightened them as much as I could in the tight space and so far starts nice and easy and no more clicking.
Probably should've changed the other tensioner, too, as well as the idler pully, but maybe later. They're pretty easy, anyway.
CrashTestDummy
Pearland, Texas
Replaced the last stupid plastic plug in the roof with a proper antenna. Fixed the intermittent light out on one of the bulbs in the middle dome light.
7SubTrooper
Washington State
Did my first mobile 1 synthetic oil change on the 07 Sub. Just took it into the dealer for my first one. 137k on it and the oil still looks clean.
Put 500+ miles on her. Now has 159k
ASG-MikeS
