least expensive way to drop my hoe
Max
Mile High
Denver
You're still not funny dude. It's chill tho my pops humors himself all the time we just ignore him :cheers:
road1will
road1will
pretty pretty good
Johns Creek, Georgia
I have almost 100k on my truck running extremely well. Here is a list of the napa part #s you'll need
Inner Tie Rod Ends - NCP 2693124
Outer Tie Rod Ends - NCP 2693122
Idler Arm Pivot Assembly - NCP 2683717
Idler Arm Assembly - NCP 2683714
Pitman Arm Assembly - NCP 2681673
Gusset the idler pivot assembly to the frame like so:
idler-pivot
Also look at replacing the intermediate steering shaft with a borgeson billet piece, part #000937
https://www.borgeson.com/catalog2/product_info.php?products_id=782&osCsid=84e702d91dff9b0f4409bca55937c3f1
What exactly are the signs that the ISS needs to be replaced? I know they are a big problem area for our trucks...but i've never heaerd what the symptoms of a worn ISS are...
Max
Mile High
Denver
I aint trying to be. I just dont like lowered shit. :adminpower:
Well that's your fault for being a douchebag then.
Steering wheel clunks, random uncentering of the steering wheel, excessive wheel adjustment at highway speeds. There is a bunch of info floating around, makes the trucks steer alot better tho.
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
even sports cars? sedans?
---------- Post added at 12:02 AM ---------- Previous post was at 12:02 AM ----------
sting!
REally no. Changes the look in a bad way.
---------- Post added at 12:56 AM ---------- Previous post was at 12:56 AM ----------
So why waste your time reading a thread about lowering? I wouldn't come and chime in a thread about making ur neck more red......
:Plugged:
I wouldnt care if you did.
Modded
That Guy
LoL RT is a lowered hater....typical Republico conservative **** who believes "his way or no way">>>>lol RT I'm joking!
By the way RY why dont you lift the kon.....just don't want to?
thumper_ehhhhh
Canada ehhhhh
man you guys missed it. the cheapest way to lower your hoe is to let the air out of the tires. It might drive like shit but it is the cheapest.
Fyrcaptain
Richmond, VA
Max,
What is the reason for gusseting that idler pivot to the frame like , and what is that blue part?
Modded
That Guy
LoL some certain people are attemtping to ***** this thread!
Max
Mile High
Denver
Max,
crikey enough questions dude? do a bit of reading off cognito's website and you'll hopefully understand. they try selling you the entire pivot assembly and include the gusset, just welding a gusset for a napa replacement piece is more than enough imo
taken from cognito's website:
The Cognito Motorsports pitman idler arm support kit takes care of the issues with the centerlink side of the pitman and idler arms. There is however another weak link in the front IFS steering on the 6 and 8lug GM vehicles. The idler pivot assembly tends to wear out, bend, and even break under stress with as little as 35” tires. The idler pivot assembly is what the idler arm is mounted to, and pivots on. Cognito offers an aftermarket idler pivot assembly in order to strengthen your weak stock parts. The aftermarket Idler Pivot assembly has tapered roller bearings, adding strength and durability, thus creating a solid pivot point for your steering components. It doesn’t stop there. The idler pivot assembly mounting tabs tend to twist or even dislodge from the frame. Included with the kit is a weld in gusset in order to strengthen the weak factory mounting tabs. This kit is highly recommended, even more important than adding our heavy duty heim jointed tie rods. Play in the idler pivot can cause major tie rod issues. If the idler pivot assembly has an issue, the idler arm is able to move uncontrollably. As this happens you will have drastic tie rod angle changes. In certain instances a bent or failed part can cause complete disaster to your front end. Some damages may include: idler arm rubbing the transmission oil cooler lines or motor mount, pitman arm, idler arm, and tie rod breakage. Most tie rod problems stem from worn or damaged pitman and idler arms or idler pivot assembly.
DESIGN
North Texas
Max, corrected me if I'm wrong but don't you do this for a living? At least i thought I remembered that from TF.
Either way, I am very interested in doing a complete suspension uprgrade and rebuild. My nearly 100k 03 Tahoe is in need to some suspension work.
My plans over the next two months are to piece together a complete set up and put it on all at once.
Key components to my upgrade are a 3/5 drop, sway bars, and new shocks (I have the oversized rear ones but not autoride). I will also take your advice and upgrade the stock components and mine needs the steering shaft repleacement.
So from the experts, what is a good budget for these parts?
Long winded post but all (helpful) input is appreciated.
Thanks,
Jon
Max
Mile High
Denver
I'm trying to finish skoo but work at a shop to pay the bills. I'd say 3/4 ton keys, belltech or mcgaughys springs, airlift helper bags, bilsteins, shock extensions, and all the front end stuff. I'd figure about $1000 for parts, front end stuff is expensive check out www.rockauto.com
tybardy
everyone needs a Hoe
Gilbert Arizona
i really want to drop my hoe... REAL bad... of course i catch a lot of shit for wanting to drop a Z71.
whats stopping me is the money its going to cost for me to drop the truck if the same cost to do things i REALLY want like LTs and Cams and all that...
anyways, Max still brings up a good point about the Inner + Outer Tie rod ends, Idler arm's and pitman arms... i am almost 100% sure i need to get all this shit replaced in my truck ASAP.
Rollin Thunder
Va Beach Va
Preformance first, defiantly. I wanna do the same mods here. I wanna cam, headers, exhaust, etc. Then next year after the shock of the new room, New outdoor kitchen, new car, my bad tax bill, wears off. I will put a super charger on the silverado, and get some headers, cam, CAI, exhaust for the yukon.
tybardy
Gilbert Arizona
how neccesary would you say those airlift helper bags are? or is that just a recomendation for those who already have the autoride?
Rollin Thunder
Va Beach Va
IM not sure. My 06 had auto ride and my 07 does not, Cant say I notice much different other than the 07 might have a firmer ride.
My silverado has ride control and I can tell you the helper bags really help when I have a ton of weight in the bed (like 50 sheets of drywall, or lumber, and stuff)
D Rollins
