qukon 95
:thumbsup:Well after a cut on my left hand thumb looking in tool box and one on right hand thumb while taking out ujoint I installed the nickel plated slip yoke and test drove it so far so gooood no clunk
Or shifting from a full stop then accelerating
Gzes
the drifting 2dr
Wichita tx
95escahoe
Got the pass side Denali door panels in and heres the driverside seat bottom done (just need to cut out the holes in it) and missing the one speaker grille was cleaning it
_Dylan_
STAY FROSTY
Went to change the leaky schrader valve on the low side a/c port, but it was completely seized and I broke the tip right off it. It ain't coming out now.
The good thing is GM in their infinite brilliance designed the serives ports to be welded the manifold so I gotta replace the entire suction and discharge line assembly, yay!
Instead they could've used something like this:
The whole a/c system needs to be rebuilt anyways...:poop:
chaingun427
OBS Mad Scientist
Mooreland, OK
finished installing the floor shift for the 4x4, and cut the hole for the trans shifter in the carpet. Trying to figure out Hoe to get the carpet back in smooth street it was cleaned
95escahoe
Installed the pass side Denali woodgrain bezel, need to take it off and fix a damaged clip on it tho, so it fits better
SunlitComet
OBS Jedi-Do Good
unknown at this time.
I would have said replace just the valve core but that port looks like it may not be that cleanable and might have plugged the orifice valve in the process.
Gzes
the drifting 2dr
Wichita tx
Got both oil cooler lines. Just gotta put them in. Same goes for the blend door actuator... fun tasks... not
_Dylan_
STAY FROSTY
That's what I was trying to do, but the top of the core sheared off and I can't remove it now. It needs a new manifold line.
When I get done moving next week I'm going to flush it, put new seals on, new drier, new orifice tube, put a vac on it, and try putting 21oz of computer duster refrigerant (r152a) in it and see what happens. My truck doesn't have rear a/c and it couldn't ever keep up before with r134a.
I'm tempted to take a few winds off the blower motor and upgrade the wiring too to get some more speed. I dunno if my evaporator is clogged with shit or what, but it doesn't blow worth a damn on high.
Elpescador100
dump the e3 and use delco 41-993or autolite xp605 equivalents.
regarding the e3 Swap.... can you give me more info on the plugs you recommended.. and why.. also i want to change out the wires as well... if you can recommend the best wires please that would be great.... and thank you,...
noJeepshere
Bountyfull, Utahrd
http://www.tahoeyukonforum.com/forum/showthread.php?t=29095
cent frum a smaert fone
---------- Post added at 04:55 AM ---------- Previous post was at 04:51 AM ----------
Having run E3's, I found they provide no benefit over standard plugs. I would say just run them until your next change.
jerryjoe28
That Guy
cabot AR
He is recommending you go with Delco 41-993s or Autolite xp605s ( what I run btw). Or another equivalent iridium plug. Vortecs run best on iridium plugs and they will last longer.
For the wires I would run the AC Delcos or the MSDs ( what I run)
Elpescador100
My attempt at under hood insulation Still not done yet.....
I used 3/4 inch DynaMat ..... going to use 1/4 inch for the Cowl area....
99YukonSLT
Ohio
My truck got broken into the one night I left it at work so I could take my other car home. Whoever did it took my cd player, cd's, and old tom tom gps. The worst part is, that rather than just break the window, they tried prying the door handle out, which didn't work and just messed up the door and all the rods/latch. Then when that didn't work, they broke the window :/
So now I'm on the hunt for a passenger power door. I've got the hookup on the body work with a buddy but finding a clean (not completely rusted) door around me is next to impossible.
Korbin_A
