Clean07Burb
replaced the lost/stolen center cap. also started it for the first time in a week!
Doesn't that piss you off! I had one center cap stolen off my Cadillac while the car sat at BWI airport. ONE center cap! Who takes one? I guess someone who lost only one. Lol
VA929RR
You said "BWI"... No further explanation is needed..... [emoji19]
NGAneer
NWGA
I see. Thanks for the tip.
---------- Post added at 10:58 AM ---------- Previous post was at 10:56 AM ----------
This is exactly what I was referring to in my original post. I'd prefer to use a relay that is sensitive to the correct voltage than an adjustable timed relay. I'll search around for the Jatronx one you mentioned. Thanks.
ETA: Just did some research on the Jatronx voltage sensitive relays. It seems from reading a member of HIDPlanet's forum that all I would have to do is simply replace the relay(s) that come with my Morimoto kit with these voltage sensitive relays. Its as simple as that. Using these relays I could then remove the resistor I installed which disabled my automatic headlights. Here's a link to the thread about the Jatronx relays for anyone interested.
http://www.hidplanet.com/forums/showthread.php?50662-JatronX-relay-in-place-of-Morimoto-relay
Correct. If the relays you are replacing at 4 prong, then you won't have the "override" functionality of the Jatronx relay. If you're replacing a 5 prong, then the extra wire (pin 87a I think) will act as the override and latch the relay no matter what the sensing voltage is. (I did not have either option as my H13 bixenons use a controller as the relay. I wired mine in between the fuse panel and the headlight plug.) Check the Jatronx description for the specifics.
Clean07Burb
Awesome. Thanks, man. Answers exactly what I needed to know.
Fosscore
Got my 24s mounted up today. Boss 333s got a good deal on them used. Not perfect by any means but love the look. And found some used Lexani LX-Nine 295/35/24s for dirt cheap.
Looking good NS!!
riggz
North of Atlanta, GA
Coming soon. It took me all day as I started on the brakes then had to wait on USPS to deliver the lift, then the instructions in the ReadyLift kit were pretty crappy and in some cases incorrect. I didn't get to wash it so it's pretty nasty.
Plus I need to get some threaded rod to extend the rear autoride sensors.
powerhaulic
adirondack mts
Installed aftermarket fog housings which use H3 bulbs
Swapped out the 20w bulbs for 55w much better now!!!
Got housings for $32 inc shipping bulbs for $8
cheap effective upgrade
They look just like stock, but work
Jonah52
Senor ******
Cleveland
Winter finally ended for you lol
Looks good
right? lol 47 degrees today :p still haven't detailed it good yet. its filthy....
---------- Post added at 11:05 AM ---------- Previous post was at 11:05 AM ----------
Installed aftermarket fog housings which use H11 bulbs
those won't melt the housings will they?
---------- Post added at 11:06 AM ---------- Previous post was at 11:05 AM ----------
Installed K&N Cold air intake. I will post pics little later
did it make a big sound difference? hows the truck feel? I'm wanting to get one just not sure if its worth the money
Joew311
TX
Do you have a link?? I hate the dogs they put on these newer trucks...my 2005 silverado had amazing fog lights that you could drive with and my 2013 suburban's barely light the ditches at all!
powerhaulic
adirondack mts
http://www.ebay.com/itm/111624406000?_trksid=p2057872.m2749.l2648&ssPageName=STRK:MEBIDX:IT
they come with H3 20w
I swapped em out for H3 55w
Works great
the plastic inserts that come with housings are very brittle so i just used the ones from stock housings, also used stock adjuster screws
GalaxyBlackEsky
BlackedoutLT3
MD
I haven't really gotten on it yet. But when doing a little pull getting on the highway def sounds meaner.
Drewphil
