Me and "Big Blue" - New to the forum, '05 Denali
Brake_L8
Alexandria, VA
Figured I'd register and make an intro post, since I do have a few questions about my new daily driver, and likely will continue to have more as I pile on the miles.
Just picked up a 2005 Yukon Denali right after New Years' Day. It's Blue Green Crystal (the only color I wanted) with about 127k on it. Was a one-owner, local truck and serviced exclusively at the dealership near where I live. Seems pretty loaded with rear-seat entertainment, second-row captain's chairs, sunroof, etc. Not sure what was standard vs. options once you got into the Denali trim level.
In any case, I picked it up with the intent of towing my track car, which is an E36 BMW M3. The car + trailer combo is about 6,000 lbs, so I wanted something that would pull that with little effort, and allow me to sleep/work out of the back during the track weekends.
It handles like a drunk baboon on roller skates, rides like a Barcalounger, gets horrific gas mileage and I absolutely love it. I'm a BMW/Euro guy, but the domestic trucks are really where it's at for utility - and the Denali was the nicest, cheapest option that could tow what I needed.
I was able to get partial service records from the dealership, so I know what's been done from 99k to today. It had the cooling system replaced, as well as tie rods, pitman arm and idler arm.
There's an occasional shimmy in the front end, that comes and goes between 45 and 65 mph. Nothing specific brings it about, and if I get on the brakes when it shimmies, it will occasionally get worse. I do have the optional 20's, and I have to think they are hard to keep balanced well. Not sure what else it could be. My old BMW 5-series would exhibit similar behavior and that was due to blown out control arm bushings - but I hear the GMT800s don't really go through bushings/balljoints unless they are in a wreck. This one has never been hit.
Also seem to have a power steering leak. It's been miserably cold lately so I plan on taking it to a local shop on Monday. Looks like a leak from the steering box.
Any ideas re: shimmy would be appreciated! Glad to be a part of the forum, hoping it'll be a good resource.
clandr1
Dallas/Fort Worth, Texas
Have you had it aligned and balanced yet?
Welcome to the site!
I also own a 2005 Yukon (non-Denali) and bought it new. I've put 128k on it, and other than some periodic maintenance and routine wear items (water pump, brakes, tie rods/pitman/idler), the truck has been fantastic.
OHSIXX
Milwaukee
Welcome....love my 06'. I get an intermittent shimmy as well-no rhyme or reason or speed-its there and goes away. I also have the optional 20's. Started when I put new Nittos on...have to get to my buddies shop and see if I need a re-balance or something.
TheAutumnWind
Looks great!
Does the air ride work properly? If not I suspect thats some of your handling issues.
A Barcalounger is a recliner apparently... Had to google that one.
I wish mine came with the 20's, its a perfectly sized wheel on these big ol' rigs.
GMT800 2005 Tahoe Z71
Navy Supporting Member
:welcome: Brake_L8 to the forum.
The handling could all be related to a caster problem. I would be curious as to what the alignment readings are now and if adjusted what the after readings are. Air pressure and tread wear patterns? The 45-65 vibes can be what I stated or a tire problem or a balance problem but if the tread patterns are funky no balance is going to fix that. The alignment shop should check steering and suspension thoroughly and I also think you have problems with the front and rear sway bars bushings and links. I can assure you that a dealer would have to see a completely failed part before they say that it is bad and needs replaced.
---------- Post added at 01:57 PM ---------- Previous post was at 01:57 PM ----------
How do i post ???
What? :hmmm2:
Love the color of your denali! Looks like you're already getting god advice on your issue :)
01ssreda4
Nice ride buddy. I hope your trailer has brakes (Im sure it does) cause these trucks need the help. There should be a brake controller harness available that makes the controller unit a plug and play deal. Very handy.
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
Have somebody shakedown your front end. Probably a loose tie-rod end really.
Big wheels even if factory with big heavy tires take a toll after 100K miles on them.
Truck looks nice though! Congrats and Welcome! :)
Brake_L8
Brake_L8
Alexandria, VA
Well, I never got notified of more replies past the first one. Sorry for going MIA!
I had the truck checked out by a local family-owned shop. The steering box was leaking, badly, and it needed the passenger-side tie rod replaced. I know you can re-seal the steering box, but I told them to put a new one in it to ideally eliminate slop in the wheel. I seriously didn't know the steering was supposed to feel so good on these trucks. Every GMT800 I've driven has had the worst steering, and mine feels really good now.
Replacing those two parts and getting it re-aligned eliminated 90% of the shimmy issue. There's a little tremor still, but that could be wheel balance. I'm not concerned.
Hooked the trailer up yesterday and got the M3 loaded on it for a tow to the shop for a wheel bearing replacement. I had pulled just the trailer before, but this was the first time with the car on it. Total of about 6k lbs.
The trailer is an 18' steel closed deck, with electric brakes on both axles. I have a Tekonsha P3 brake controller (super easy to set up) and this truck pulled the load like nothing was attached. I was considering something smaller at first (Grand Cherokee, 4Runner, Touareg) and I'm really glad I picked the Yukon. The only indicator I was towing was checking my rear-view mirror and wondering who the a**hole in the BMW was that kept tailgating me! :p
YukonJerry
I have the same issues and rims on my '06 I hate it but love the car.
adventurenali92
Big Bear Lake, ca
Nice ride! I'm am new to owning a Denali as well.just picked up a 2006 XL. When I decided to buy a Denali, that was the color I had my heart set on. I love that color. But I couldn't find a Denali in California in that color. I ended up scoring a bitchin deal and mine is silver. Which I don't mind because silver is the second easiest color to clean, especially because I'm a detailer and I live on a dirt road. I'd be curious to know if that shimmying is due to wheels. My Denali is riding on the stock chrome 17s. I like the wheels mine has but I really want the OEM 20s that yours has. Or another set I've seen on the Denali that looks good. But if it's gonna cause that shimmy than I'll stick with my 17s. Would love to know what your result was for that issue!
Brake_L8
Brake_L8
Alexandria, VA
Congrats on the new truck!
The shimmy was largely due to a worn-out steering box and passenger side inner/outer tie rod. That made things quite a bit better. I do still have a bit of a shimmy that comes and goes around 65 mph. I'm wondering if it's wheel balance and/or a bent wheel. I'll be due for a new set of tires toward the end of summer, so I'll have it all checked out then.
I'm about ready for an oil change and would like to do filters and other fluids while I'm in there. Thinking I'll do spark plugs, oil, cabin/engine air filters, diff fluids, and brake fluid. Not sure what is recommended for any of that, and will have to do some searching on here. I can tell you the go-to brands for anything BMW-related but this truck is a world full of clueless for me so far.
I did tow down to VIR a few weeks ago with my M3 on the back of it. Holy hell, it's amazing. Very glad I got this vs. a smaller SUV as I was initially considering (Grand Cherokee, X5, Touareg). It'll do 70 mph no-sweat with the car on the back.
OHSIXX
Milwaukee
Sent you a PM.
pnwdan
Cunning linguist
Arlington, WA
Nice set up. I too am a euro guy. down to one E46 for now. Sold my E30 show car back in the summer. I picked up my Denali to tow my cars around too.
Eickybobby5050
