TheAutumnWind
Ya, I cant wait, i have a 13 Camaro 1le, and my wife has a 13 malibu...and i did too much work to the camaro to be a daily so i bought the yukon (lol, its my gas saver compared to the camaro now) but it was a huge disappointment on how spongy/soft the brakes are compared to my other vehicles...so i did some research and I was also going to do the hydroboost upgrade also, but i have the adjustable pedal and i dont know if i want to have to swap that all out to...so hopefully ill be happy with what im doing.
I've been quite impressed with the brake feel on my denali xl with a stock hydroboost setup FWIW.
01TX_Tahoe
Semper Fi
Pasadena, TX
Well guys, i decided since I was due for a brake job to go ahead and do the gmt900 upgrade, 07 tahoe (raybest rebuild) calipers and brackets, wagner pads, and russle braided brake hoses, and ebc dimpled and slotted rotors
are those a direct bolt on? what year is your truck?
clandr1
Dallas/Fort Worth, Texas
Changed the alternator (195k) on original). Also changed the oil and filter
How did you know it was going out?
I had a pulley bearing go back in the alternator on my 1989 Jimmy. It would squeal a bit, and got REALLY hot even after idling for just a couple of minutes. I've always wondered if my Yukon alternator would go out in a similar fashion, or if I'd notice the voltage regulator was toast (jumping voltage).
seven9st surfer
Milton, FL
Got my 7" and 21" led light bars on the mail, took them apart and painted all the hardware black. Plan on sealing them up with silicone and figuring out the mounting tomorrow.
05Yukon23
Arkdelphia, AR
Haven't posted in while. Life happened. ANYWAY, lowered her 2/3, ordered wheels, new shocks, and other small things.
Question: I found a back glass for an eacalade I would like to get for $300. Is that a good deal and has anyone had trouble with a body shop painting it your color?
Red_Raider
Derby, Kansas
I finally pulled the trigger on all of the parts I've been needing to order. So here is a quick run down :
Bilstein 5100s front and rear
Moog z71 springs
Rotor and pads front and rear
Oil pump
Oil pan gasket
Oil pressure sensor
Transmission tail shaft seal
Intake manifold gasket
Knock sensors and harness
Z71 fogs
Timing chain gasket
Smoke Em All
Taylor,Texas
Well I actually did it last Saturday but, I put a new upper control arm on the driver side. Not a difficult job at all.
Yngbld32
Hoover,AL.
Got me some twentyfours....Craigslist find.
rob3827
philadelphia, pa
Battery light would come on when it idled. The volt meter on the dash would fall. Took it to pep boys and they tested it. It failed all test. The new one was $190(I had a $30 gift card)
Maic
15 Suburban LT / z71
Houston, TX
Int. light mod.
Added more light inside. Replaced the 2nd and 3rd dome lights.
Anyone doing this, pay attention to the colors on the plug. Had to re-pin one, nothing major.
Smoke Em All
Taylor,Texas
So a replaced my other upper control arm and did a tire rotation yeaterday. Almost had a serious uh oh moment today. For whatever reason I didn't get one of my wheels tight and nearly lost a wheel today. Luckily I was driving and felt it shaking so I tightened them up and all is well.
seven9st surfer
Milton, FL
Truck wouldn't start again. This has been intermittent forever. And whenever I get it towed to the shop, it fires right up, so they can't diagnose it. Not throwing any codes that I can see. I replaced the crankshaft position sensor today, but it still won't start. I'm thinking fuel pump, but I'm going to see what the shop says.
clandr1
Next time this happens, take a rubber or plastic mallet and bang on the fuel tank. If it starts up after doing this, it is most likely your fuel pump.
JochenWoern
Sacramento, CA
Really torn on how much to lower the beast with my wide ass wheels.
My opinion, ...................... and nothing more, ......................
Put your old wheels back on, as they looked much nicer than the wheels with rubber bands for tires.
wwiizz
