Fixing the Famous *CLUNK* Noise
992dr
N.C.
If you park on level ground, yes.
I parked like this, with my front end lower than the rear. No trans fluid came out.
YukonCrazy
YukonCrazy
Raleigh, NC
I had napa machine shop press out and press in the u-joints from driveshaft and new slip yoke. I bought 2 new u-joints from napa because I wanted ones with zerk fittings. I removed the old trans extension piece and installed the new one. Greased the yoke splines and installed the driveshaft. Took it for a ride and no noise over speed bumps and no **clunk** when stopping and taking off.
992dr
N.C.
Great news, I'm glad it worked out for yah.
royskiies
do truck have 2 slip yoke? sorry a newbie want fix this problem myself
992dr
N.C.
Nope, only one.
Two u-joints and 1 yoke.
992dr
N.C.
Thank you sir, the nickel plated yokes are the new part that came in to replace old? Are those need to bee grease as well
Any time, glad I could help.
Not sure about the nickel plated ones replacing the old. I got mine from GM, not sure if its nickel or not.
No grease, put some trans fluid on the shaft before inserting it.
Kkkkpppp
