Fixing the Famous *CLUNK* Noise
YukonCrazy
YukonCrazy
Raleigh, NC
The new slip yoke and u-joint arrived from Fort Wayne Clutch. Picking up the new tail shaft this afternoon. Question. What is the procedure to attach the u-joint to the yoke and driveshaft?
992dr
Eastern N.C.
The caps should slide off. You may feel some pressure, its more than likely the grease inside has caused a suction.
After the caps are removed, slide one end up into one hole of the yoke and the other should fall right into place.
You'll need a press to install the caps, some people use a large C-clamp or vise or they beat them in with bfh. And finally, put the lock rings in place.
Make sure there's plenty of grease inside the caps when you re-install them.
YukonCrazy
YukonCrazy
Raleigh, NC
Any particular kind of grease?
992dr
Eastern N.C.
Bearing grease should be fine.
Is there a zerk fitting on the u-joint?
992dr
Eastern N.C.
No zerk fitting.
OK, when you pop those caps off, put a little grease inside before putting the caps back on. They usually come with some grease in them but, a little more wont hurt anything.
Are the u-joints the heavy duty ones?
YukonCrazy
YukonCrazy
Raleigh, NC
Not sure. It was included with the slip yoke from Fort Wayne Clutch. Pictured below. Should I replace the u-joint on the backend of the dirveshaft as well?
Here is a link to the u-joint they sent me.
http://www.fortwayneclutch.com/inde...niversal-joint-made-by-aam-pn-s-12479126.html
992dr
Eastern N.C.
You can, its up to you. Check its condition and make that your deciding factor. I did both of mine at the same time only because I took my driveshaft off and brought it to a shop to do the work.
Thanks for the link, I appreciate it.
YukonCrazy
YukonCrazy
Raleigh, NC
So when I take off the trans tail housing, a lot of transmission fluid is going to come out?
992dr
Eastern N.C.
If you park on level ground, yes.
I parked like this, with my front end lower than the rear. No trans fluid came out.
YukonCrazy
YukonCrazy
Raleigh, NC
I had napa machine shop press out and press in the u-joints from driveshaft and new slip yoke. I bought 2 new u-joints from napa because I wanted ones with zerk fittings. I removed the old trans extension piece and installed the new one. Greased the yoke splines and installed the driveshaft. Took it for a ride and no noise over speed bumps and no **clunk** when stopping and taking off.
royskiies
do truck have 2 slip yoke? sorry a newbie want fix this problem myself
992dr
Eastern N.C.
Thank you sir, the nickel plated yokes are the new part that came in to replace old? Are those need to bee grease as well
Any time, glad I could help.
Not sure about the nickel plated ones replacing the old. I got mine from GM, not sure if its nickel or not.
No grease, put some trans fluid on the shaft before inserting it.
AdrienR
