Added 3" Keys and 3" Spacers(PICS)
EvontayeCannon
Alabama
Well installed keys and spacers the other day, and here is the outcome. I also removed the pin-stripe. I have to add shock extenders because the ride quality is AWFUL.
TxDrewski
Potomac,MT
Also looks like you need to tighten the hood to the mount on the passenger side :)
Looks good though!
uncleiceberg
SoCal
5100's?
I just cranked the keys all the open on my 05 since I'm trying to squeeze 17's wrapped in 35" tires buuuut a need about another 2"s it seems and I am not sure how to go about that.
NathanJax
Vacation Nathan
Jax, Fl
looks good!
uncleiceberg
SoCal
Damn.
@fire730, my post keeps deleting itself.
Yes, 2wd.
Have 17" rims wrapped in 35" tires
Minimal rubbing but would like turned keys enough to get an inch and a half but would like an additional 2-3"s.
What and where do I get the following:
"ford" torsion keys?
Bilstein 5100 shocks?
Any additional suggestions?
Thanks guys
Ib
Lookin Good!!!
I agree on 5100's
I removed the airride off my YD. Went keys and spacers with z71 springs and Bilstein 5100's all the way around and don't regret it a bit!!!
ccd_1606
Kentucky
I just purchased a used yukon that had large spacers in the rear. It has the rear shocks topped out. Will shock spacers fix this. Mine has the non air auto ride so I didn't wanna do away with those shocks.
YukonXL04
The Riverboat
Arlington, TX
yes you can add shock spacers in the rear. however if it has been driven for a while with the shocks topped out, chances are they are now damaged anyways and will need to be replaced.
Mudfrog
Lookin Good!!!
I agree on 5100's
How much extra height do you get from the Z71 springs? I'll be doing the Keys / Spacers in a few months, trying to plan ahead.
01Konvict
Boats n Hoes
Raleigh/SML
Most get 1/4" but some say they have gotten an 1". I only got 1/4"-3/8" with mine but maybe you can be lucky and get more.
Mudfrog
Does it help with the ride any when doing the keys / spacer? I'm sure my springs are saggy as I have 160k on the Tahoe. I'd like to run a 32.6" - 33" tire, I really would prefer not to trim. I know the biggest thing is wheel offset which I still need to figure out.
I honestly can't answer that cause my Denali had lowering springs on it.
---------- Post added at 08:28 PM ---------- Previous post was at 08:07 PM ----------
Well it helped my ride quality cause it was a ****** lowering job.
They cut the bump stops readjusted the ride height rods and they backed the keys all the way out. So yes helped mine drastically.
Has for wheels I had stock 17s w 285/70r17 no rub. Now my current wheels are 0 offset 275/60/r 20s At full lock I rub inner fender a tad.
dizhai
