anyone bagged one?
NASTY GM
Nor Cal
Nice... Hows the ride with those universal bags? How much lift do you get with those bags? How low do you drive it? Do you have pics of the rear setup? I noticed that u have aftermarket upper control arms... I'm more concerned with the ride quality since it is a "family" car.
I never measured the lift the fronts give but its planty. The ride depends on the heigth. It seems to ride best in the middle. I ride with it low, up high and raked one way or the other, I'm always playing with it. The front are DJM arms that Aaron installed but are not needed. Here is a crappy pic.
Young28
The Yukon God
ga
damn didnt know you chromed all that mess. nice
NASTY GM
Nor Cal
Ya, it looks cool through the wheels while parked and while driving behind or on the side. To be honest most people don't even notice, but car guys do :evillol:
NORCAL SS
SUV SUSPENSION GURU
Does anyone have pics with the trailblazer ss bag installed and how the rear looks when its played out? Also, what other front kit is there other then the kelderman front kit? I am not looking on laying it out but just to get it sit on the tires...
Norcal SS - what will happen if you drive it lower then 2.5 to 3" drop?... I currently have your rear springs but would prefer the bags. Have you tried riding it lower? If so, how was the ride?
with the tbss bags installed you can roll at about a 4 inch drop max. If you drive lower the ride gets bouncy but the rear bags from a tbss will ride lower then any kit out there at ride height. Brad here posted up he had the kelderman rear kit and swapped to the rear tbss bag. Sat lower/more lift/towed better and rode better
For what like 120 bucks its worth it.
Nosho47
Cool... I picked up the tbss bags today from a friend. It is not from a tbss but from a 06' envoy denali. I'm still deciding on what front setup to get. The universal air looks really simple to do and will save me some time installing instead of fabricating lower control arms and upper control arm brackets. The question is if I was to lay out on the running boards or even the frame later down the line, will the universal airbag work?
NORCAL SS
SUV SUSPENSION GURU
tbss bags are a shorter bag then other models.
Nosho47
So your saying that its not the same bag as the envoy denali?? It looks exactly like the one you posted... What's the measurements of the bag collapsed and inflated?
Nosho47
Do you have the aero sport or power sport airbag for the front?
I have Universal Strut bags on the front. They replaced the springs. I'm running Belltech adjustable struts but their not needed.
The rear I have Conitech bags.
Mine sits on the fenders front and rear on 26's. Heres a few crappy pics.
Nosho47
Are you using stock spindles with the universal bags or is it drop spindles?
shundal
NorCal
When I contacted them last year, they said they use the power sport on the GM trucks. They have a few avalanches on their website done with them.
NASTY GM
Nor Cal
Belltech drop spindles, Belltech adjustable struts and DJM arms. I don't think any of it is needed. The DJM arms help keep the wheels from tipping in when its down.
NASTY GM
Nor Cal
I don't think so. I still have 2 rings on mine. Mine would go lower if I cut up the inside top of my fenderwell. I plan on laying mine out so I just going to wait till then,
NathanJax
Vacation Nathan
Jax, Fl
So if I use 4 it don't matter since it won't lay anyway
The front will tuck and rest on the fender on the tire if you remove the rings. So if you use more rings, it will not go as low...
sixpack19
broken arrow, ok
That's right when I installed the drop struts I never used any rings. Ok.
Also with those sport strut bags from avs does it replace the front spring on the strut? Using everything else.
NathanJax
Vacation Nathan
Jax, Fl
I'm pretty sure they do. That's how my kelderman's do. Just remove the spring and replace with the bag
sixpack19
broken arrow, ok
Nice thanks. Since I already have norcal drop getting all air ride is half done. Easiest air ride I can think of. No link kit for rear or trimming front frame cups just front rear bags and all air components!
Bentley95
