2015 Denali LED Fog Light Replacement
hosseface
hosseface
Philips led > OE 921 by far.
Perfect match to Sylvania led 194 plate lights.
Before and after pics.
Deepthought
There is a bracket directly beneath the fog lamps, but you can reach around it to access the back of the lamp assembly, no disassembly required. Squeeze the locking tabs to unclip the lamps out of the housing. I uttered some "bad words" when trying to get the new lamps locked back into the housing, but it was a matter of leverage, persistence and a good small flashlight.
Matt
hosseface
hosseface
I think I want to grab some of these, do I have to pull the fender liner or just reach up behind the fascia? ;)
10 minutes max. You can reach right up into them from under the front bumper. Just release the 2 little plastic clips that hold the bulb in.
I'd highly recommend ordering you a pair of the Philips 921 LED backup lights if you don't already have LEDs in them. They are amazing.
Be prepared to grease your arms all up. Don't know why, but the 2 metal plates under/behind my front bumper looked like GM did me the favor of rust-proofing them for life by dipping them in a vat of chassis grease prior to install.
zolt11
+1 on the chassis grease. Took me much longer to clean my arms than to install the vleds. Lol
kasperfh
Arkansas
Can you provide a link to the Philips reverse lights? Cannot find them online. The iJDMTOY reverse lights have good reviews on Amazon but I had rather go with a more trusted brand like Philips.
hosseface
hosseface
thank you good sir. The description says you can choose form 4000k or 6000k but the picture shows 6000k and amazon doesn't have any option to choose. I'm guessing you received the 6000k when you ordered them?
10-4
mitchmawby
Couple more pics after LED fogs:
i know that you posted the link for the LED fog lights but what is the actual part number?
I have a 2015 tahoe im doing the same thing to and trying to determine if they are the same.
Thanks.
hosseface
hosseface
FINALLY just ordered these. Hopefully will get to throw them in this weekend :)
Man its about time.
Whats up with "2015 Yukon Denali #1 - Custom HMI, IPC and BCM"
Where's #2?!?!?
GTPprix
Senior Member
Metro Detroit, MI
I have the first production (Non Manufacturer) Denali, no number two needed LOL I probably should take that out LOL
WinePress.US
I just got my 921 back up LED lights and am waiting on my Putco LED fog lights... How hard are they to swap out? Do I have to remove interior panels in the back to get to the back up lights? bumper or just reach from underneath? Can I reach the fog lights from underneath in the front as well? I have a 2015 Yukon SLT. Your assistance is greatly appreciated.
Thanks,
joel
WinePress.US
I got my set of tail lights and fog lights. I got the fog lights switched out. Does anyone have recommendations or can direct me to the best and easiest way to replace the rear back up lights? Thank you for your assistance,
joeel
varminpoolteam
