Fuel filter 2008 Yukon Denali
Tony
Does anyone have any info about what it takes to change the the in tank mounted fuel filter? Mine is defintely clogged and clogging the injectors. Is the part attached to the fuel pump? I dont know why there is next to no info on this subject available online, is this top secret info? lol
Goodinblack
I Like Tacos
Dirty South
That part is changes with fuel pump.
Drain tank. Drop tank. Remove lock ring etc.
The fuel pump, sending unit and a bag type filter are basically a unit.
You change the in line filter?
Tony
Tony
I was under the impression that it just had 1 fuel filter that was built into the tank, which is part of the fuel pump? Are you saying that there is a secondary fuel filter??
wrager
I don't believe there is an inline filter. I hope I'm wrong 'cause life would be easier. I use Techron additive at every oil change on the '10 Sub.
Tony
Tony
I tried using that, it cleared up the problem only temporarily, so therefore there must be dirt in the tank or the filter must be clogged.. I know there is no inline filter but i hear there is one in the gas tank..
JasonW4141
