Too much tank with a roll pan
BigCountryx
Anyone make a replacement fuel tank that won't be so visible with a roll pan installed?
ravingmadman
Chief Knuckle Buster
Greater Seattle
Take a picture of what you're trying to cover up? I'm confused. Or retarded. Or a little of both. It's early.
I was looking into this also. On the other boards they were saying to use the fuel tank from the K5 blazer, it is suppose to be slimmer. I haven't found any info on this.
B
BigCountryx
you mean the roll pan does not hide the tank enough? No Idea.
That's exactly what I mean, This is a picture of what I am talking about.... This is not my Tahoe, only used as an example.
ravingmadman
Greater Seattle
Wow. That's horrible. It looks like some sort of injury. It also looks like the lowest point of the rear of the vehicle, which is a huge liability. How do you not scrape the thing?
Effeckt
Resident Cards Fan
Phoenix, AZ
Definitely agree with everything that has been said. I would definitely look into that K5 tank or another one of smaller size that can tuck up inside the truck.
B
BigCountryx
I've got a K5 too, guess I need to break out the tape measure. Wonder if the sending units are similar.....
foreverfalcon40
WTF are you taking about?
Dont forget the pic ur using in refernce the guy is hitten the floor with an airbag set-up...maybe that the culprit...keep searching
---------- Post added at 09:34 PM ---------- Previous post was at 09:33 PM ----------
CKendrick
