max lift to clear 20x12 305/55/20
chacho44
MOTORCITY
Ok might buy the wheels soon. Whats the max to clear these, turn clearance. 3"?
WildBill
a 12" rim is really wide for a 305. It should be more like 9". What backspace? if youre more than about 5.5" your rim will contact suspension. For a 9" wide rim keys are fine.
chacho44
chacho44
MOTORCITY
They are stretched on there but thats the look im goin for. Its a socal thing, seen a lot on lifted trucks. I've had 305's on my stock 20" and they rubbed while turning but worked fine, this time I wanted to do the wider rim but know it will rub the bumper or running board
01Konvict
Boats n Hoes
Raleigh/SML
You will need to trim front bumper valance and crank the keys. Its going to rub when turning close to full lock but another guy on here has 20x10s with 305 and made it work
imi4tth3w
i have 20x12's and 305 55 20's on my tahoe. i have a 6" rcd cranked to 7" and had to trim. good luck trying to run that setup with just a leveling kit. although the trail graps i have run a little bigger than some other 305 55 20 or 33 1250 20's out there.
my build thread link is in my signature if you want to see more pictures.
---------- Post added at 06:49 PM ---------- Previous post was at 06:43 PM ----------
the x12 wide wheels are made in a -44mm offset. they are not going to touch the suspension. without proper lift though your tires will be rubbing the fender and bumpers due to the wide stance.
yes if OP went with a narrower x9 wide wheel with a 0 offset or even slightly negative they would probably be okay with a 3" leveling kit. 20x10's -24mm offset and 305's would rub pretty bad. 295 55 20's can work with trimming.
you will need a 6" lift to run 20x12's and 305 55's. unless you don't want to have a bumper or fenders anymore.
Z-56 Hoe
What do I do????
Houston
Matt you need to bring that beast to Houston sometime.
What gears are you running and what kinda MPG do you get?
WildBill
Hmmm the 20x12s look a lot better than I expected! I would agree that a lot of lift would be needed for that offset and width.
vtxtexan
