My bagged 07 Yukon... pics & info...
Young28
The Yukon God
ga
i have 2 captains chairs as my second row..didnt want bench no more. I honestly dont see why you couldnt add a third row seat. You may have to have custom seats made. But for 1 seat like nathan has now..i dont see why not.
red02chevy
Lubbock
Good comparison pics from my tahoes. First 2 pics are my current tahoe (guess I didn't take a finished pic) buttom pic is when I removed to bracket off my old 07
ig109
Ive seen Hoes and Burbs at shows that lay running boards on 24s and there is no way you could keep the 3rd row and actually be able to sit back there.. No way..
Young28
The Yukon God
ga
really depends on how you do the rear setup. if i didnt have a speaker box in the back i would get measurements.
Would it take work yes..will i grown man fit back there..i doubt it. but kids could.
jdpber
GOLD MEMBER
The America
Grown men can't fit in the factory 3rd row without knees in face.
jdpber
GOLD MEMBER
The America
I'm 6' 2" and it's a squeeze I can sit in middle and legs between the captains .
Bradleyj
These pics are just the Kelderman, correct.
I did mix n match and that's why I took so long to take/post pics. You have to use OEM or direct replacement shocks (I have Monroe) because the size of the holes the bags go on to on the strut (if that makes sense)
I tried it with and without drop and I still have the Belltech camber kit in.
In the rear the bags replace the springs so nothing you can so there. I do still have the DJM rear kit (shock extenders, shorter swaybar endlinks and trailing arm relocation brackets)
but that's it.
did you have the drop spindles with the kit and then go back to stock spindles? I also have the Kelderman kit and am looking to go lower front and back.
NORCAL SS
SUV SUSPENSION GURU
is the bumsptop bracket cut off the frame in rear if not it wont go anymore lower.
NORCAL SS
SUV SUSPENSION GURU
that rear piece will drop rear 2.5 inches more by taking it out when you lay itout on frame.
on 305 35 24 with the piece out and rear end bottomed out truck will measure 30 inches about from ground to fenderlip.
NORCAL SS
SUV SUSPENSION GURU
yes on the bagged trucks ive done this mod to i had to take the bags out since sawzall blade will slice the bag.
also if your bags arent short enough it will bottom out the bag before it bottoms out the axle on the frame. This is why i use the trailblazer ss airbags. Ride better and also at ride height sit lower than other baggged set ups.
gryans07yukon
stockton, ca
I have slam bag he 7 all around and rides good.. back goes up real high. I like slam bags alot and there very durable and tough
---------- Post added at 06:07 PM ---------- Previous post was at 06:05 PM ----------
*re 7 .. im still messing around with truck need to put my spohn hard pan bar on also.. next gonna get upler and lowers for rear
NORCAL SS
SUV SUSPENSION GURU
yah trust me tbss bags sit lower at ride height and ride great plus can bring up rear over 5 inches over stock. bolt in pretty much and only 150 bucks and you can tow 6500 pounds
Bradleyj
Can I buy the TBSS bags from you?
---------- Post added at 05:53 PM ---------- Previous post was at 05:43 PM ----------
Hey NASTY, I see you decided to go fully custom from Aaron Iha, did he do a cantilever setup in the rear? I went with the Kelderman kit and now I'm trying to get lower in the rear so that it actually looks like I'm on bags. I'm in Nor Cal and trying to decide if its worth driving down south. any advise would be appreciated.
worleytrev93
