Removing Roof Rack... Some questions...
RMP91
I'm planning on de-'racking my '00 Tahoe LS 4x4 and I've read that you can risk ruining your interior from water damage if you don't do it right (plugging the holes, that is).
Has anyone done it here? How did you do it? Any $ involved? How did you cover and plug the holes in the roof without making them stand out or leak?
Your input is greatly appreciated!
-Ryan
04whitetahoe
TYF PLUS!(tm)
Lincoln, Calif
Stainless button heads from Lowes W/Silicone
I'm planning on de-'racking --plugging the holes, that is.
-Ryan
Hey Ryan,
I just did it, get 10 of these from Lowes:
I cleaned the holes with alcohol wipes and put a dab of silicone on the screws before tightening in.
Done:
:thumbsup:
ashelm
Overland Park,Ks
I did mine last year. Went to the auto glass store and ask them if they would fill the holes with there window sealer and they said they did not want to do it BUT they would GIVE me a tube of sealer and I could do it. DUPONT # U-418 Quick Cure Primer less Auto Glass Urethane Adhesive. You know how well your front window seals. This is the same stuff!!! It is black color. Scott
NeverSatisfied
eBay Baller
Wichita, Kansas
I just went and got some way shorter screws to put in there nothing else haven't had a single problem been a few months since I've done it
R
RMP91
I forgot to say that I want to be able to reinstall the roof rack if circumstances require it. So actually "sealing" the holes permanently is not an option for me.
But I like the ideas you've presented. I'll give it a go after the New Year when it ain't so busy around here...
-Ryan
WHITEOUT
Dont Hate-Appreciate
Phoenix
Always go the spiked route :hmm: Have had mine for few years, they screw in and sealed, but still able to remove if ever wanted. I also may want to use my rack again and didn't want them permanent. Haven't had issues with water or anything.
But you can see others have used many different things. Screws/bolts, button head, allen head, flush ect. Plastic caps and supposedly make a specific cap used for PPV vehicles. Could do a rubber strip or seal to cover over all holes. Just depends on how you want to cover them up.
NeverSatisfied
eBay Baller
Wichita, Kansas
Where did you get the spikes at?
WHITEOUT
Phoenix
I made them. I didn't actually make the spikes themselves. I got them locally, but they also sell them online. Just had to drill and tap for correct size bolts. Made a set for someone else few yrs back when I made mine, idk who tho.. Mike (tahoewhat) is making some similar, supposedly!! Giving hard time Mike.
Just wanted something different.
Tahoewhat
Ballin' on a Budget
TX
Lol. all good man. But yes, i have been messing with the idea of putting spikes up there. Its different and unique. Mine will be tad different than Whiteouts though.
But alot has been stated as most do to cover the holes up. I myself put inset screws in, they mount flush and then put some sealant on top and have no issues w/ water at all. But you can see where the bolts go. But, im pretty low though.
Tylus
South GA
Hey Ryan,
Done:
:thumbsup:
thanks for that photo. I have been unable to figure out how hte damn retainers go into the body. how are those retainer nuts held in? Prior owner removed the roof rack and all the retainers and left me with just holes. I bought new retainers...just can't figure out how they stay inside the roof
04whitetahoe
TYF PLUS!(tm)
Lincoln, Calif
Hey Jeremiah,
I don't know this for a fact, but I suspect it would be either a special tool like a pop rivet gun that would expand them while in the holes or they would be glued in with a super strong epoxy type glue.
Maybe there's some body work types on the forum that could chime in?
You could call a body shop in your area and ask them - they might tell you.
Joe
josueh95
hey guys idk if its just mine but my tahoe does not require to put some srews on there to cover up the holes..its already sealed i removed my roofrack and its been lyk that for over two years with no problems
vsaravia
