:lol:
Smokymance
Boosted
MI
Washed the wheels and sprayed Permanon on them.
Also did the fender liners with it .
that stuff work pretty good????
---------- Post added at 09:54 PM ---------- Previous post was at 09:52 PM ----------
I had to get some grade 8 bolts for my shorter end links today....stuff that came with the kit wasnt the best....also changed the rear/front/transfer case fluid to all synthetic, as well as did a trans flush...coolant is next
hitch closeout arrived today
Goodinblack
I Like Tacos
Dirty South
Yes, it is. Though you have to take into account that a 50mL bottle needs to be diluted and makes about 16 oz.
Supposed to last about 2-3 months.
All you do is literally spray it on, and hose it off 45 seconds later. Beads water just like if you waxed the car.
Does the permanon resist road salt?
Yes.
Although if you want to correct your paint before sealing it I actually would recommend CarPro CQuartz.
2:30 is impressive
[yt]bWAYheALaZc[/yt]
---------- Post added at 07:37 PM ---------- Previous post was at 07:33 PM ----------
GM style?
Street Scene style. I like it better as it's less "bulky"
08grey
Yes.
2:30 is impressive
GM style?
Want to use on chrome wheels.
Goodinblack
I Like Tacos
Dirty South
Permanon is really easy.....
Spray on
Wait
Hose off
Durability is not as good as a sealant type product though.
That's why I say do a coating type product
Yukon liftgate appliqué is set to arrive today :)
Yes along with the hitch close out.
blkonblk
NYC
At the dealer getting the oil changed and replacing the rear window motor (replaced the same motor 9months ago nobody sits back there lol). I have 53k on the trck and they are recommending to flush the brake fluids($175), transmission fluid ($350), and all the axles ($550). In the manual they are all recommended to be done at this point. Where can I get this done cheaper? $1k for fluid flushes seems high
You can get it done cheaper in your driveway :D
blkonblk
NYC
Lol if I do that myself also I will become a gm certified mechanic, I do everything else myself Wonder if we have any how to in here
Sent from my iPad using Tapatalk - now Free
Goodinblack
I Like Tacos
Dirty South
Changed the rear axle fluid in the 2011 Yukon XL. Fluid was black as motor oil at 60K.
For anyone who wants to know........
1. Rear end gasket IS REUSABLE........ in my 2009 Suburban and the 2011 Yukon XL.
2. Capacity is 3 bottles and 3/4 of the 4th bottle of 75/90 Synthetic. So buy 4 bottles.
3. Rear pan hard bar must be undone at the axle mounting point for ease.
4. Drop the spare tire and move out of the way.
5. When putting the panhard bar back in....... the holes may not line up...... don't fight it...... simply jack up the rear of the truck up.... and the holes will line up as the bar moves laterally to the axle.
6. Clean the magnet inside of the diff cover. On my 2009 the magnet was removed and cleaned. On my 2011 the magnet is epoxied to the cover and should not be removed. Just clean it as is.
7. These steps are obviously out of order.
Phlipnstik
