Big brake kit help needed
jasonconway5
Its about time for brakes, but I don't want to waste money on the stock brakes. I have 18" wheels and 285/65/18LT Nitto grappler tires. They are very heavy and make this tank even harder to stop. What's the most inexpensive big brake setup I can get thats going to actually make a difference on my braking distance? Also, has anybody ever gotten a bigger kit then nit be able to find pads? I want to go cheap, but not so cheap the company I buy from closes shop and I'm no longer able to find pads.
NathanJax
Vacation Nathan
Jax, Fl
Have you looked in to upgrading to the NNBS brakes? The swap requires calipers/brackets (usually sold together), pads and rotors. The current brake lines can be reused but I'd go SS while I'm at it.
jasonconway5
jasonconway5
Thanks! Where csn I find it???
Z-56 Hoe
What do I do????
Houston
2007 Tahoe's and up front brakes only keep your rears! Look at R-1concepts. Get their drill and slotted 2007 and up fronts and new 2000-2006 rears that are also drilled and slotted. I'd also do SS brake lines and Hawk pads or EWC
You will need the brake calipers and caliper brackets for a 2007 and up Tahoe
Knobz
Santa Cruz, CA
It's not the easiest install/swap but only set you back $200 maybe and that's converting to the hydroboost brake booster. It oy came in 3/4 ton models and escalades. But I've heard that mod is the best bang for your buck. A family member has the 2004 Chevy suburban 3/4 and it has the hydrobooster and it stops than things like it has 6 piston calipers
FreshLikeOprah
Hey, just wanted to let everyone know. The 05+ pickups with drum rears also have the same calipers and rotors as the GMT900s. So that might make it easier to find them in the junk yard, etc. And yes, they come loaded from AutoZone for $99ea with a $50 core charge.
Sasquatch
Orange County N.Y.
I`m about to do the 07 rotor swap but i was wondering if they take older calipers as a core for the 07 style or do we have to eat the core charge?
Travieso
Boooooooost !
Los Skandeles, CA
My 2006 Chevy Tahoe Lt Flexfuel came from factory with Hydroboost :shrug:
Danzigman
Galveston, TX
I am about to do this install as well. I have everything except the calipers. My plan is to install the '07 calipers and return the originals as the cores. They don't know what they are looking at in the store, they will take them no problem. Just don't say anything! :emotions33:
a4edwin
ny
I did they can't tell the diff they'll just open the box and see the caliper and bracket. I even returned them with the old brake pads still inside.
jomulk56
Resident Lurker
IN
Can you do the swap without the braek booster? Is there a prefered model/part number everyone has used?
JasonW4141
