alternator swap
Tim Burks
hey guys, ive searched the forums and cant find what im looking for, i heard of a factory 200 amp alt rpo code kyu i think, and was wanting this alternator for my truck to help with low voltage problems. any idea what year and truck this came on? and will it wotk on a 01 yukon?
thanks
Z-56 Hoe
What do I do????
Houston
Why not get a PPV Tahoe 220 amp or a power master hi output one my wife and I both run power master hi output altanators
T
Tim Burks
Where did you get it? Im looking at all options.
---------- Post added at 09:31 AM ---------- Previous post was at 08:20 AM ----------
ive been looking for the PPV replacement, but none of our part store has a clue what or where to get one....
imi4tth3w
xs power makes some great alternators. they aren't cheap though.
cheapest/easiest option is to go with a reman 145A alternator as thats what a lot of the newer models come with from the factory
04whitetahoe
TYF PLUS!(tm)
Lincoln, Calif
Looking at alternators too - I made a list
Hey Tim,
I have been looking at alternators too. Here's a list of products you may find helpful - you can plug in your year/model for fitment considerations:
300 Amp for $650.00 - Assortment of high output for high $$$$
http://nationsstarteralternator.com...004&Make=Chevrolet&Model=Tahoe&Engine=5.3L+V8
250 Amp for $348.00
http://www.powerbastards.com/products.asp?cat=129136
250 Amp for $300.00
http://www.motorcityreman.com/tahoe...hoe-yukon-ad&gclid=CKWjx7ftoLoCFYpxQgodvU8ApQ
240 Amp for $350.00
http://www.nationsautoelectric.com/ad-244.html
225 Amp $349.00
http://www.qualitypower.co/item/Powermaster_48237_and_18237/330/c67
220 Amp for $349.00
200 Amp for $255.00
http://www.knukonceptz.com/productDetail.cfm?prodID=8292
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Alternator-New/_/R-NNE1N4812HO_0209450717
200 Amp for $299.00
200 Amp for $315.70
http://www.dbelectrical.com/p-5192-...igh-output-200-amp-alternator-96-05-8237.aspx
160 Amp for $216.70
http://www.dbelectrical.com/p-9754-...-160-amp-43l-48-53-60-silverado-03-04-05.aspx
150 Amp for $200.00
145 Amp Remanufactured for $75.35, new for $128.98
http://www.partsgeek.com/catalog/2004/chevrolet/tahoe/engine_electrical/alternator.html
145 Amp From $105.89 and up
http://www.rockauto.com/catalog/x,c...ck[PHP_SESSION_ID],nlrg9j0b8ejk2dv1nvtc2h9bu3
145 Amp new $149.99
http://shop.advanceautoparts.com/we...-p?navigationPath=L1*14920|L2*14999|L3*15587#
New 145 Amp Duralast Gold $159.00
http://www.autozone.com/autozone/pa...lx9uZ93xme?itemIdentifier=973439_191266_4452_
145 Amp New from $119.69, Remanufactured from $95.80
http://www.autopartswarehouse.com/search/?Ntt=Alternator
Large assortment of products
http://alternatorparts.com/ad230-ad244-series-high-output-alternators.html
Make sure to do the Big 3 upgrade while you're messing with your power system!
:thumbsup:
ccapehartusarmyINF.(ret)
Gilbert AZ
okay what are you running to get low voltage problems im assuming some aftermarket insane wattage car stereo amps
what kinda of voltage readins are you getting at the batt terminals , at idol, under load , car off , also take a voltage reading at your car stereo amp, if you battery is kickin out less then 12. 2 volts or so its a bad battery also the big 3 deal my solve alot of problems for example after i did that upgrade i get almost 14 volts to my amp
becuase i have an 02 tahoe i think its got a 105 amp alt i got a brand new optima and all zero guage wiring and my 5 channel is like 1300 watts rms my lights or guages dont fliker wehn the bass hits nothing no problems
and if you have an insane stereo system there is also a dual alt kit so you can just install a second alt right next to the current one
dbtahoe01
i have 4 320amp iraggi alternators. Best amp for price ratio.
each of my alts bench more than 320 amps at 2-2.5k rpms
a 220+ amp alt
big 3 is a must!
and a agm battery. you shouldnt have any voltage issues.
i cold start at 15.3 and once warm the truck sits about 14.8.
i had 2 powerbastard alts prior to this setup (that i bought from a member here, sold his truck through) and they didnt bench 250amp and charged at 14.3
my current setup also has a vcm which is usually set to 15.1 for demo's or 14.9 daily which isnt much different from where they usually sit at 14.8 anyways... full tilt i drop to 14 with 12-13k rms, that was only with 4 batteries. new build with have 6 Group31s in the back and 2 group34's under the hood and a bunch of 2/0 ;) shouldnt have much if any voltage drop ;)
T
Tim Burks
sorry i havent been back to read yall's info, i found a 253 amp delco replacement for $200 new with warrenty and upgraded all my wire under hood with 1 awg wire. found my factory alt (130 amp) was getting weak and was causing all my problems. not running a huge stereo, but its decent, little over 3k rms. with this alt and a bigger batt under the hood im getting 14.4 at the amps and staying over 13.6 on music. now time for more power!
T
Tim Burks
Ill get you the part number after work
---------- Post added at 07:27 PM ---------- Previous post was at 06:38 PM ----------
Its a Delco Remy part# 8292N-253A. I bought locally from a reman shop. Dunno which part stores carry delco remy, but you can check.
2001_yukon
i normally sit at 14.8 with a 300 amp alt and 2 batteries but i can adjust it depending on what im doing in the truck, civic on the other hand is a spl monster lol
dbtahoe01
dont charge your batteries to long at 15.3... i use to set my vcm at 15.1 for demo's but 15.1 is too much for 12v batteries, especially xs power.. xs power told me not to go over 14.9.. so be careful at 15.3 anthony
anthonyz71
Black Death Bubonic
rockaway , nj 07866
It all apart now just rebuilding for 2014 season. New box . Last season was running the 6 12" in my 15cube Aero box on 3 6ks got pics of that if u texted me send u pics and if u fb my u can see videos
AnthonyZ71. (862)222-5821
Eickybobby5050
