Why is it so hard to find 06 denali sway bar size!>
Hummin24
Hey guys trying to re do my front and rear sway bar bushings and end links. I can't find anywhere online what size the front and rear bars are. I want to make sure I get the right bushings the first time. Its a 2006 denali air ride awd with stock 20's. Thanks.
-BIll
06 yukon
93 H1
Hummin24
Hummin24
If you go on Rockauto there's a few different sizes to pick from.... I ended up going with the 1 5/16ths hopefully they fit.
Hummin24
Hummin24
Bump. Ordered by year and model from rockauto. Nope didn't fit.
franksbanks
Arizona
I just did my 03 Denali with a set from prothane.com
Part number 7-1169
1.25" sway bar.
They fit just fine
TheAutumnWind
Ok I have an '03 'Nali XL. Y'all think my sways are 1.25" front and 1.18" rear?
00-05 Suburbarn & Tahoe 1/2, 3/4 Ton 4WD- Front Sway Bar Bushing Kit, 1.25" Bar 7-1169
00-05 Suburban & Tahoe 1/2, 3/4 Ton 4WD- Front Sway Bar Bushing Kit, 1.42" Bar 7-1168
00-05 Suburban & Tahoe 1/2, 3/4 Ton 4WD- Rear Sway Bar Bushing Kit, 1.10" Bar 7-1171
00-05 Suburban & Tahoe 1/2, 3/4 Ton 4WD- Rear Sway Bar Bushing Kit, 1.18" Bar 7-1172
Aaron_L
Arlington, TX
It's not hard. Just put a dial caliper on the sway bar. If you don't have a set of calipers, just find an open end wrench that just fits around the bar.
TheAutumnWind
Yeah I need to get calipers...
Looks like mine on my '03 xl nali are 1.4"
01ssreda4
Ebay calipers are less then $20. Every tool box should have a pair.
Drewphil
